Go to Post What should the lesson of FIRST be? Work within your resources to build the most effective machine that you can--and, at the same time, work to increase those resources. - Billfred [more]
Unread 24-01-2013, 17:31
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: How far are people shooting?
Yesterday, our prototype shooter (CIM and miniCIM directly driving 2 8" AM pneumatic wheels) was easily firing across our 30' practice room with little vertical drop.
Our team plans to be versatile with shooting positions, as we have our shooter on a tilting mount, but I expect we'll primarily be firing from the back of our pyramid and from the feeder station (if we can get adequate accuracy at such a long range)
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 24-01-2013, 20:11
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Originally Posted by Kevin Selavko View Post
You will have to shoot over the net, would be pretty impressive
That curve.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 25-01-2013, 00:58
philso philso is offline
FRC #2587
How are your motors holding up? We were using an 8 inch AndyMark FIRST directly mounted on a mini-CIM shaft and got some good shots until the motor bearing gave out.
Unread 25-01-2013, 01:16
4057programmer 4057programmer is offline
FRC #4057
4057programmer is an unknown quantity at this point
FIRST team 4057 has a prototype shooting accurately from 55 feet out at 60% power. It was at this time we realized the hazards of testing inside as we ramped up the power and put a dent in the duct system in the school.
Team 4057: Autodesk regional Rookie All-stars!
If it's not on fire, its programming. If it compiles, it's electrical
Unread 25-01-2013, 01:35
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Originally Posted by SoccerTaco View Post
If you pop forward solely to draw a foul, does 18-1 come into play here and negate the foul on the blocker?
Rule 18-1:
Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of FRC and are not allowed. Rule violations forced in this manner will not result in assessment of a penalty on the target ALLIANCE .
No, the rule regarding the feeder and pyramid safe zones specifically designates that it doesn't matter who initiates contact.
18-1 is intended to prevent things like loading discs into another robot so it has more than 4 or pushing an opposing robot into one of your own partners that is trying to climb, so that the opposing robot gets huge penalties.
Unread 25-01-2013, 01:59
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
Our shooter has been tested at 27 feet into the top goal consistently, but we've shot 50+ feet into someone's outstretched arms 7 feet in the air. Need some more testing
So far, some of the most important things We've learned is that:
There has to be a stable, stable back wall.
If it's a circular shooter, more compression tends to shoot it farther.
No skid tape helps a lot.
Our shooter was shooting like 10-15 feet, and it was a bit disappointing. We were about t give up, but we just moved the wheel in like 1/4 in, and it started FLINGING those things out to 40 feet or so.
Unread 25-01-2013, 17:07
Custom User Title
AKA: Cal
So far they're ok as the motor is well supported, but we haven't run it much yet.
Unread 25-01-2013, 18:36
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
i believe our robot will be capable of shooting from feeder station but i fear a defensive robot will park infront of us nd block us. is that legal?
Unread 25-01-2013, 18:45
DanielCH's Avatar
DanielCH DanielCH is offline
FRC #0295 (Renevatio)
Team Role: Driver
DanielCH is an unknown quantity at this point
As long as they adhere to space restrictions, yes.
There is no rule against simply being in the way of a shooting robot, but there are plenty of rules you could break while doing so (pinning, etc). See section 3.2.6 "ROBOT-ROBOT Interaction" of the game manual for more information.
Unread 25-01-2013, 18:56
Andrew Lawrence
Posts: n/a
We're planning on scoring a little more than over 9000 from the goal. Give or take a little.
Unread 25-01-2013, 19:16
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Oh, y'know, we're attending Greater Kansas City, but plan on outscoring OP Robotics at their regionals...
Academic Student (Forever)
Unread 25-01-2013, 22:01
DonRotolo's Avatar
Back to humble
FRC #0832
We shoot from about 60 feet away. But the frisbee doesn't go nearly that far
From 12 feet we're 100% easily, from 25 feet almost but not quite, we are seeing some curve at that point. They tell me 40 feet is not bad, but I have not seen it myself.
Unread 25-01-2013, 22:37
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
We're shooting about 20ft dead straight, no wheels.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 26-01-2013, 18:02
DonRotolo's Avatar
Back to humble
FRC #0832
No wheels? Care to elaborate? Sounds fascinating.
Unread 26-01-2013, 18:42
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
30ish feet
http://www.youtube.com/watch?v=rafV51xbnOk
