Go to Post Go with what you know will work, and try a little less if you are feeling brave. That is my rule of thumb. - sanddrag [more]
Unread 25-01-2013, 06:54
Re: Vision Processing VI Problem
It sounds a bit like IMAQ, or NI-Vision is its other name, may not have been activated. You can do this in the Start>>National Instruments>>NI License Manager. You may need to contact NI support in order to complete this, as I find it pretty confusing to use.
The other option is that you don't have the newest version, in which case the solution is to install it from the DVD. Hopefully the dialog will give you an idea of which is more likely the problem.
Greg McKaskle
Unread 25-01-2013, 09:33
wdburk3160 wdburk3160 is offline
AKA: William Burk
FRC #3160 (F.R.O.G.)
wdburk3160 is an unknown quantity at this point
I do have the newest version. I will reinstall labview on that computer when I get the chance. Thanks for the replies.
Unread 26-01-2013, 12:27
AKA: William Burk
Thanks for the replies, we got Labview reinstalled on that computer and now everything is fine.
Unread 10-02-2015, 22:31
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
Greg McKaskle
I had this problem, too. I thought I had activated everything during the install but I guess not. Activating through NI License Manager fixed it.
Thanks Greg
