#16
Re: Predicted Match Scores at Championships
Thats 92-122 depending on climb/colored disc score. Last edited by EricLeifermann : 24-01-2013 at 10:12. |
#17
Here are my assumptions.
Good elimination teams on Einstein will have 2 climbers and a scorer. They will also have all three robots participating in auto. My guess is 8 3 point goals in Auto - 48 points 2-30 point climbers (one with a top dump) 80 points Somewhere in the mix the alliance will score an additional 16 3 points 48 points 10 point climb for third robot 10 points Total (again this is the high score...) 186 points Now some conjecture.... If you could have two 30 point climbers that could top dump you could have 2 more 5 pointers +10 You might be able to add another 6-3 pointers +18 Absolute finest score................... 214 Now theoretically you could have auto 11 in auto... (which is doable...) so that would be a 66 point auto maybe even more... but the total absolute max for auto would be 15 3 pointers.... maybe more if you could steal some from the center line. That is a 90 point auto. You combine that with 3 30 point climbers and all of the top scores. that adds 90 + 30 or 120 points... Add in 16 more 3 point scores... 48 You get a 258 (but it won't be done...) Better chance: 1 robot fires in 45 3 point shots......shooting from full court 135 points Autonomous 9 shot auto for 54 points... 2 climbers Plus top dump of 6 disks.... 90 points total in this extreme case: 279 Again it won't be done... One sees pretty quickly that a score above 200 requires an extraordinary alliance. More than likely, scores in the 150's will be exceptional CMP scores.. As more teams recognize what a team is capable of... defense will shut some of the scoring down (at the expense of offense for the team doing the defending...) My personal opinion is that AUTO will rule the matches.. A team can't defend the other team's good autonomous... A good climber will cancel out another good climber...shooters can be defended.... slight differences in auto scores will make a big difference in the game. |
#19
![]() I'm surprised how similar 2006 was. Distribution is tail heavier... but otherwise basically the same. 2006 Game Animation, for reference. (3 pts per ball in high goal, 1 pt per ball in low goal, 25/10/5 for 3/2/1 robots on the ramp at the end of the match, and a 10 pt bonus to whichever alliance scores the most points in autonomous) Draw your own conclusions about robot ability from those scores, they aren't broken out by how they were scored. For example, every match could have had a 25 pt ramp bonus... but as I recall they were not that common. Last edited by Ian Curtis : 25-01-2013 at 01:41. |
#20
Dupe
