Go to Post we were sick and tired of compromises: "speed or torque", "traction or maneuverability", etc.; bump that, we want it all. all we had to compromise was simplicity. - RogerR [more]
Unread 24-01-2013, 16:29
C.I.S. C.I.S. is offline
FRC #4607 (Coalition of Independant Students (C.I.S.))
C.I.S. is an unknown quantity at this point
Lead Screw Inquiry
We are using a screw drive on our robot to move a system of 3 pneumatic cylinders on a track. Does anybody know what size/kind of lead screw we need?
Unread 24-01-2013, 18:01
tsaksa's Avatar
tsaksa tsaksa is offline
FRC #0997 (CHS Robotics)
tsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond reputetsaksa has a reputation beyond repute
Re: Lead Screw Inquiry
Your selection of a lead screw will be based on the parameters of your design such as. How far do you need for it to move back and forth? How much space might be taken up by a carriage. What precision will you need in your motion? How much force is this lead screw expected to encounter? How fast does the lead screw motion need to be? How are you planning to drive the screw? How will it be, or can it be supported at the ends? etc.
Many commercial lead screws are more precise and powerful than needed for many FIRST applications so you may be able to get by with a lower cost/grade of lead screw depending on your design. A low carbon steel screw with a plastic nut in 1/2 inch diameter or even smaller should work for a wide variety of applications. But if this is intended to do serious work such as lifting the robot, then you better research the answers to the above questions carefully before selecting a lead screw.
This is the zeroth day of the rest of your life.
Unread 24-01-2013, 20:51
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
I read the title as "Lead Screw Injury". I was extremely confused as to how someone got injured with one. I think I may finally need sleep after 3 weeks.
I'm right 90% of the time, so why worry about the other 3%?
Unread 25-01-2013, 00:03
tsaksa's Avatar
Lead is a very heavy and toxic metal. It is also far to soft for reliable use in most mechanical applications. Why anyone thought it was a good idea to make screws out of the stuff is beyond me. It was only a matter of time before accidents started occurring.
Unread 25-01-2013, 00:12
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
I did the same
But theres atleast 3 more weeks without sleep left!
Originally Posted by tsaksa View Post
Your selection of a lead screw will be based on the parameters of your design such as...
snip
Quoted for truth. It really depends on a lot of specifics. Ex: Different turns per inch result in differing amounts of speed and precision.
If you know how fast you want the stuff to move, you can do some calculations regarding rpm turns required to travel one inch.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 25-01-2013, 08:47
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
....... XD
Unread 25-01-2013, 08:50
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Originally Posted by BeltSanderRocks View Post
I did the same
That makes 3. I also read it as injury. Kinda interesting.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 25-01-2013, 09:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
If you're doing something serious with the screw like lifting your robot, get in touch with an applications engineer at Nook Industries. Tell them you're participating in a high school robot competition and what your parameters are and they can help you pick an appropriate lead screw or ball screw they have in stock. We used them for the leadscrew inside our telescoping arm in 2011 and they were extremely helpful.
Unread 25-01-2013, 10:53
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
My limited experience:
-Precision grade lead screws/nuts from McMasters are only slightly more espensive than the junky stuff, worth it IMO.
-Make sure you're not going to exceed the critical rotational speed on your lead screw.
Unread 28-01-2013, 12:20
Joe.Quirk Joe.Quirk is offline
FRC #1817
Joe.Quirk is an unknown quantity at this point
Anyone know if the lead screws from Mcmaster are fully threaded? On a related note, does anyone know how, or the best way to make the ends into a regular round shaft to it can be applied to a motor or fit into a bearing?
Unread 28-01-2013, 12:35
Yes they are fully threaded. The best way to do the end-prep is on a lathe, obviously. If the screw is hardened and not cutting well, you can temper the end by heating it up to cherry red or orange with a torch and then letting it slowly cool.
