Go to Post Every single person on the team, read the manual, cover to cover, NO skimming. Do not give the task of knowing the rules to a few people. Do not pass go, do not collect $200, READ THE MANUAL. - RoboChair [more]
Unread 15-01-2013, 08:21
AsianRookie AsianRookie is offline
AKA: Steven/Tim
FRC #0321 (Robolancers)
AsianRookie is an unknown quantity at this point
camera not showing
Hello guys, I wanted to view the camera in the driver station smartdashboard, but when I click add, it does not show Camera as a selection. In default dashboard, the camera is enabled and works. So is there anything I have to configure?
Unread 15-01-2013, 12:11
Re: camera not showing
Did you configure the camera for anonymous viewing? See http://wpilib.screenstepslive.com/s/3120/m/8559/l/89729
Unread 16-01-2013, 17:10
AKA: Steven/Tim
yes, but it still does not show up. Also it is now disabled by default.
Unread 19-01-2013, 11:59
2472Programer 2472Programer is offline
Programming Captain
AKA: Dane Jensen
FRC #2472 (The Centurions)
2472Programer is an unknown quantity at this point
Our team is having the same probem, and the autonomus viewing didn't fix anything
Unread 19-01-2013, 12:08
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Team 3260 programmer here, we are having the exact same problem. Anonymous viewing is enabled and we can see the camera through the online page but the SmartDashboard is not displaying it. I've tried rebuilding all of the SmartDashboard/WPIJavaCV/NetworkTables/(pretty much everything that we have access to the source of) but I have yet to find a solution. We have tried completely resetting and reconfiguring the camera, using the automated utility, plugging it into the radio, and plugging it into the cRIO all to no avail.
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
Unread 19-01-2013, 14:26
SuperMario SuperMario is offline
FRC #3692
SuperMario is an unknown quantity at this point
This may sound stupid, but I spent 2 hours trouble shooting and I just typed the ip wrong in the SmartDashboard, is your ip right?
Unread 19-01-2013, 14:28
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
I've checked the IP a few times and even tried assigning a completely different IP address to the camera. The "Default" dashboard wouldn't work if it weren't set to the correct IP, either.
Is there any chance you could send me your entire SmartDashboard folder? (Extensions and all) I'd like to see if it is simply a build related issue.
As a Mentor:
As a Driver:
Unread 19-01-2013, 14:31
FRC #3692
I would but I am at home now and we don't meet again until Friday because this week is finals for us. Hopefully some other team could.
Unread 21-01-2013, 18:21
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
Has anyone had any luck getting this to work? We're still without camera in our SmartDashboard.
As a Mentor:
As a Driver:
Unread 22-01-2013, 08:20
AKA: Steven/Tim
Also I tried to use a modified camera widget displaying a crosshair, and that also did not work. There was also an update to FRC tools, but it did not fix anything with the camera problem.
Unread 22-01-2013, 08:26
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Check what the fps is for the stream. We had an issue where SmartDashboard Camera did not work if it got a fps under 30.
Unread 22-01-2013, 16:29
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
Where exactly is this setting? I couldn't seem to find one in the Camera's setup portal.
As a Mentor:
As a Driver:
Unread 25-01-2013, 09:41
wjbrauck wjbrauck is offline
Team Mentor
FRC #0768 (Techno Warriors)
wjbrauck is an unknown quantity at this point
I'm having the same problem with the Smart Dashboard. Default Dashboard shows the camera image just fine, so I believe that indicates the camera is configured correctly. SmartDashboard does not connect to the camera.
In addition, if I launch the SmartDashboard from the driver station I don't see any of the extensions widgets when I try to add a new object. If I launch the SmartDashboard directly using the SmartDashboard.exe executable all of the extensions show in the list. Camera still doesn't connect. I thought this might indicate an install problem, but I can't correct it, even after a reinstall.
If anyone has figured out how to correct these issues, your help would be appreciated.
Unread 26-01-2013, 11:39
sarangmittal's Avatar
sarangmittal sarangmittal is offline
FRC #1683 (Techno Titans)
sarangmittal is an unknown quantity at this point
In order to be able to add the Camera to smartDashboard, you'll need to download the WPILibCameraExtension and place it in C:/ProgramFiles/SmartDashboard/extensions.
Then, just open SmartDashboard, click View, and Add, and the Camera Option should appear.
You can get the WPILibCameraExtension here:
https://www.assembla.com/spaces/tech...ware/documents
Click the first file.
Hope this helps.
Unread 26-01-2013, 11:58
Team Mentor
Extension was already present. Its part of the SmartDashboard Installer_1.0.4 that also installs the WPIJavaCV and openCV libraries
