Go to Post some people sing in the shower........i pretend to be an emcee at championships......:cool: - BanksKid [more]
Unread 20-01-2003, 22:05
Don Reid Don Reid is offline
Don Reid will become famous soon enough
The input circuit has some threshold. If the input is below this voltage, it will be seen as low (active), above it will be seen as high (inactive). I'd have to see a schematic for the RC to know precisely what this threshold is (or run an experiment), but many common logic systems switch at about 1.4V.
It is possible that the input has "hysteresis" where the high>low threshold is lower than the low>high one.
You should also realize that the threshold is not precise, it can vary from part to part and can change with temperature, voltage, etc.
The digital inputs have some pull up circuit, probably a resistor. This could affect the output of your analog circuit depending on its design.
Don Reid
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Robot Digital Input Mike Norton Technical Discussion 5 16-01-2003 14:31
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
