Go to Post Good tooling doesn't cost money, it makes money (and prevents doctor visits). - travis [more]
Unread 20-01-2003, 16:59
John Larock John Larock is offline
#0365 (DuPont Miracle Workerz)
John Larock is on a distinguished road
CG of Bins
Hey, has anyone modelled and calculated or measured the specific CG (Center of Gravity) of the Sterilite Bins? Looking for height of CG from the bottom of the bin.
Thanks in advance.
John
Unread 20-01-2003, 20:04
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
The easiest way I know to do this is to ballance the bins on 2 different edges. The CG, when ballanced, will be directly above the ballance point. Doing this on two edges will give you two lines that intersect at the CG.
I don't have a bin handy, but it shouldn't take long to do this.
Unread 20-01-2003, 21:53
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
One thing I've tried before is to attach 3 strings to the outside edges of the object you are weighing. Keep adjusting the lengths of the string until all 3 have been pulled taut, and hang a weight from the point at which they meet. There's the center of gravity for that plane.
I've only seen it done once, and it was a tedious effort. Does anyone else know of a better method? Namely for 130 pound robots.
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 20-01-2003, 22:05
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
First, find a function to express the density of the box. The x-coordinate of the center is given by dividing the integral of x times the function by the integral of the function. The y-coordinate is the integral of 1/2 the function squared divided by the integral of the function.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 20-01-2003, 22:10
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
That sounds very similar to the experiment we did in my one and only college physics lab.
Brandon Martus
e-mail
Unread 20-01-2003, 22:34
Jim Meyer's Avatar
Engineering Mentor
None #0067 (HOT)
My favorite is as I described for the crates. Balancing your robot on three sides. Put some masking tape on the robot vertically above each balance point. Each of these represent a plane in which the CG lies. The intersection of these 3 planes is a single point.
You can also do this by sliding pipes under your robot, starting from the edges and moving them to the center. The pipe with the least force always moves the easiest and you always end with the pipes under the CG of the robot.
A method used for cars is to suspend your robot and swing it like a pendulum. The period of the pendulum can be used to calculate the CG.
Another method used for cars is to put scales under all four wheels and then elevate the front and measure the weight transfer to the rear, and vice versa.
What do you YOU use your bins for? AlbertW General Forum 40 13-04-2003 04:18
Falling bins are like dice GregT General Forum 18 12-01-2003 00:56
robot touching a stack of bins carlye Rules/Strategy 20 11-01-2003 02:13
tipped bins cbudrecki Rules/Strategy 25 07-01-2003 23:12
How will the bins face on the ramp? Jacqui Sutton Rules/Strategy 1 07-01-2003 08:48
