Go to Post you know the FIRST season is never over . . it just pauses a while so you can get some sleep. - Stuart [more]
  #61   Spotlight this post!
Unread 25-01-2013, 12:11
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Prototype Small Wheeled Shooter
Originally Posted by Kevin Sevcik View Post
To be more precise, there are two ball bearings on the output shaft and one (I think, don't have one in front of me) on the input side holding the input coupling. So the output shaft can definitely support some cantilevered loads.
Do remember that you're not going to be able to stick a mini-cim into this gearbox. You'll have to go with a BAG motor and a 3:1 ratio, which will endup somewhat slower than your mini-cim. So you might be better off figuring out how to make up a shaft coupling and support system for the mini-cim.
EDIT:Actually, a BaneBots RS550 motor into a 3:1 gearbox gets you a similar free speed to the mini-CIM with a bit more power. You might try that combo as a drop-in replacement for your mini-CIM.
If you're clever, with a custom mount plate and a trimmed down shaft, you can mount a MiniCIM to a VersaPlanetary gearbox.
-John
  #62   Spotlight this post!
Unread 25-01-2013, 14:21
brianwech's Avatar
brianwech brianwech is offline
AKA: Brian Wechtenhiser
FRC #4547 (WestyTek)
brianwech is an unknown quantity at this point
Originally Posted by falconmaster View Post
Thanks Team Spectrum!
We have one now
http://www.youtube.com/watch?v=zggvD...ature=youtu.be
I'd love to hear more regarding details of your shooter: motors, gear boxes, gear ratios, wheels, voltage to motors, distance between wheels, etc. Thanks.
  #63   Spotlight this post!
Unread 25-01-2013, 15:04
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
-John
I can't believe I didn't notice it was an 8mm hole until you said that.
I know what we're playing with next week. (Note: Not for our shooter)
  #64   Spotlight this post!
Unread 25-01-2013, 15:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
*blinks* So that's what that "notch" is in there for. Or so you'd hope. I wouldn't want to pin my hopes on that set screw in the CIM keyway.
Also, I have a feeling a mini-CIM would really push the limits on the load rating of the VersaPlanetary. And if you swapped a CIM in instead... Well that'd be extremely exciting.
  #65   Spotlight this post!
Unread 25-01-2013, 15:50
JVN JVN is offline
@JohnVNeun
Depends entirely on the reduction, and output shaft configuration. Check out the loading tables at the end of this guide:
http://content.vexrobotics.com/vexpr...s_20130107.pdf
  #66   Spotlight this post!
Unread 25-01-2013, 16:32
Engineering Coach
I should have pictures up in the next hour or two. I have a student doing it right now.
  #67   Spotlight this post!
Unread 25-01-2013, 17:30
Engineering Coach
Instructions are up on our blog
http://3847.blogspot.com/2013/01/ver...-mounting.html
This was a pretty simple conversion. We cut the shaft more than would most likely be recommended but that lets you directly mount it to the Versplanetary with out any adapter plate.
  #68   Spotlight this post!
Unread 25-01-2013, 17:35
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
I don't recall but, do you have any video of shooting with the disc upside down?
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
  #69   Spotlight this post!
Unread 25-01-2013, 17:42
Engineering Coach
Not from this prototype, it needs some sort of cap over the wheels to get long shots with upside down discs (think the C channel from robot in 3 days), otherwise we find that the discs rise up out of the wheels before they leave the shooter.
  #70   Spotlight this post!
Unread 25-01-2013, 17:43
I stand corrected. If you're willing to green light a 1/2" hex shaft 300:1 BAG Motor for simple loading, that's the equivalent of a 1/2" hex shaft 50:1 big CIM motor. Which at 90 ft-lbs stall and nothing to sneeze at.
Allen,
Are the black spacers for standing off an AM-9015 motor too small to stand off the CIM?
  #71   Spotlight this post!
Unread 25-01-2013, 17:46
Engineering Coach
Allen,
Didn't think about it but that does work. That will add back a 1/4in to the shaft.
  #72   Spotlight this post!
Unread 25-01-2013, 20:18
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
We just posted a blog entry about our current prototype shooter. It uses much smaller diameter wheels than many teams that we have seen post of CD. We're hoping this idea might inspire some teams that are struggling to package their large shooters.
Blog Entry with full specs on the shooter configuration.
Youtube Video
Hello guys, Nice job! We are experimenting with your setup and are having some degree of success. We have about 10 3/8 compression gap or 5/8 compression and we find the frisbee shoots straightest when the angle on the side ends with it being inline with the center of the last wheel. We do see that it goes straight , but if we make it a 1/4' longer it goes farther but not quite as straight. We also tried the gap between the two wheels at 1/4 " and with the centers 2" apart. It seems that the closer the wheels the farther it goes. We had the first wheel at 5K and the second wheel at 15k. Could you share your settings that worked best for you? Thanks. Again awesome job!
Faridodin "Fredi" Lajvardi KD7WKD
  #73   Spotlight this post!
Unread 25-01-2013, 20:31
Engineering Coach
We're nearly identical to that. BAG motors 1:1 and 1:3 wheels close together and the wall ending at the center of the fast wheel. Compression at about 1/2 inch. You have just verified our settings.
  #74   Spotlight this post!
Unread 25-01-2013, 20:44
I'd like to hear from teams -- if there are any -- who been successful spinning the 2nd wheel approx 30% to 40% faster than the second wheel, instead of 3x as fast.
  #75   Spotlight this post!
Unread 25-01-2013, 21:17
Engineering Coach
Do you have any reason to assume that is more optimal? We would like to know.
