Go to Post Neat! I like when things break, it's educational! - s_forbes [more]
Unread 06-01-2002, 14:01
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Globe motor specs
I am looking at the specs for the globe motors (rulebook G-20) and am confused.
With the "drive assembly" the no load speed is 87 RPM and the stall torque is 150 In-lb (16.95 N-m). The no load speed without the "drive assembly" is just slightly faster (97 RPM) and the stall torque is much much lower (30 oz-in, or 0.212 N-m).
How can a "drive assembly" (which I presume is a gearbox) increase the stall torque so much without significantly changing the no load speed? Or do you think there is a mistake in the rulebook?
Thanks
Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 06-01-2002, 20:50
Matt Reiland's Avatar
'The' drive behind the drive
I think the reduction is something over 100:1 on the globe so the free motor speed should be much higher than 97 if the output speed through the gearbox is that high, must be typo
We need globe motors archiver 2001 5 24-06-2002 01:30
Globe Motor archiver 2000 4 24-06-2002 00:15
Globe Motor archiver 2000 0 24-06-2002 00:15
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
