Go to Post FIRST is like pizza--you and I might prefer different toppings, but there's no wrong way to do it. - Billfred [more]
Unread 25-01-2013, 18:25
Happy Birthday! Blondie3160 Blondie3160 is offline
FRC #3160 (F.R.O.G.)
Blondie3160 is an unknown quantity at this point
Question Making AM SuperShifters work in LabView
Has anyone used an Andymark Super Shifter?
Blondie3160
Unread 25-01-2013, 18:26
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Andymark Super Shifter
Yes.
Edit: Now that it's in the right forum, and the thread topic has been clarified in the title, we can hopefully help. For what it's worth, you can think of it in terms of a tank/arcade drivetrain (depending on your preference) and a pneumatic solenoid/servo (depending on the SuperShifter you have). Understand the control logic of those components, plus a joystick button to shift, and you've got most of it right there. If you want automatic shifting, or use of the optical encoders for drivetrain control, let us know; it gets more complicated quickly.
Unread 25-01-2013, 18:28
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
Yes, The teams i personally mentor in the past 7 years have all use super shifters at one point in time. If you have any questions feel free to pm me with any questions you might have.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 25-01-2013, 18:30
Nick1912's Avatar
Nick1912 Nick1912 is offline
If ya ain't first ya last
FRC #1912 (Team Combustion)
Team Role: Driver
Nick1912 has a spectacular aura aboutNick1912 has a spectacular aura about
We used them last year on our robot, and will again this year. If you are already using pneumatics on your robot then I would recommend them.
1912 Combustion Student 2011-2014
FLL student 2009-2010
FLL Mentor 2010-????
Unread 25-01-2013, 18:31
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Our team has used Super Shifters. Is there something specific we can help you with?
1058 PVC Pirates 2016 - xxxx
Unread 25-01-2013, 18:37
Were wanting some programming help (LabVIEW)
Blondie3160
Unread 25-01-2013, 23:19
Re: Making AM SuperShifters work in LabView
Programming a pneumatic-shift gearbox is extremely easy in LabVIEW. If you use a dual solenoid, all you need to do is use two joystick/gamepad buttons.
Place two Case blocks. Wire one button's value to the select input of the first block. In its True case, set the solenoid Forward. Wire the other button to the second block. In the True case of that block, set the solenoid Reverse. The False cases remain empty. Press one button to shift to high gear; press the other button to shift low.
Unread 26-01-2013, 01:52
klinnastruth's Avatar
klinnastruth klinnastruth is offline
Engineer
AKA: Kyle Linnastruth
klinnastruth is an unknown quantity at this point
I just wanted to clarify, as the OP was a little vague. We are trying to get the Super Shifter to automatically change gears when the motor hits a certain RPM, which we are hoping to get via the encoder. As of right now we do not have much and any help would be appreciated.
I just learned of what we were attempting to do with these tonight, so I'm going to check with the other mentors to make sure I understood what we are looking for correctly, and will clarify if i misunderstood something.
Thanks in advance!!!
