Go to Post I dunno, with those Chucks, I'd be inclined to say he out-dresses the better part of DC... - Nuttyman54 [more]
Unread 25-01-2013, 18:00
Nathan Powell's Avatar
Nathan Powell Nathan Powell is offline
The Prime Function
FRC #2582 (PantherBots)
Nathan Powell is an unknown quantity at this point
Smartdashboard connection error
I have downloaded the SmartDashboard for the Driver Station. When the DS is set to C++, the SmartDashboard opens up automatically as normal. However, even when the DS has connection to the robot, the SmartDashboard does not receive the connection. I have looked at the guides on the FIRST website, but have failed to find an answer. Can anyone offer assistance?
Unread 25-01-2013, 18:34
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Smartdashboard connection error
Can you confirm that the team number is set correctly in the SmartDashboard preferences? You can find the preferences on the File menu, then click Preferences.
Brad
Brad Miller
Robotics Resource Center
Unread 25-01-2013, 18:41
The Prime Function
It's funny you mention that--I discovered that we did put the team number in wrong before making this thread. But yes, the team number is correct. That allowed the SD to come up automatically when the DS was set on "C++".
Unread 25-01-2013, 18:47
AKA: Brad
So when you say that the SmartDashboard doesn't "receive the connection", what exactly do you mean? Are you sending values but they aren't showing up?
Maybe you could try running it manually from a command line to see if there are any exceptions or error messages coming out of the SmartDashboard. Use cmd.exe in windows and type the command:
java -jar smartdashboard.jar
will run it. Let us know what you see.
Brad
Brad Miller
Unread 25-01-2013, 19:01
The Prime Function
Forgive me, I was not clear. I meant by "not receiving the connection" that the connection indicator on the SD is red even when the DS is connected the the robot. No widgets appear on the screen (we currently have one potentiometer, a victor, a talon, and a gearbox attached). And when I put your command in the cmd.exe, it responded:
Error: Unable to access jarfile smartdashboard.jar
Perhaps I did not install it correctly, and left out some files?
Unread 28-01-2013, 20:24
The Prime Function
I tried reinstalling the driver station, but with no success. The smartdashboard comes up when i bring up the DS, but it does not receive any connection from the cRIO. Has anyone else found this problem, or is it an isolated case?
Unread 28-01-2013, 23:06
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
The SD works fine for me. Are you actually sending values to the SD? Nothing will show up unless you do... *including* the connection, as it isn't initialized by default.
Unread 28-01-2013, 23:49
You need to navigate to the directory where the smartdashboard.jar is located before running it.
Unread 29-01-2013, 19:37
The Prime Function
Check that--the SD just connected to the robot. the Connection indicator is green now. I used a code I found (and modified slightly) from a 2011 thread on the SmartDashboard.
double value = 42.85
SmartDashboard::init();
SmartDashboard:PutNumber("Stuff!", value)
I guess the code, not the SmartDashboard itself, was the issue. Huh. I ws sure we checked it before uploading...ah well. Live and learn. Thanks to everyone who offered their advice!
