Go to Post I'm not basing success on winning a regional. Success is learning by building the best system you can. In the engineering industries, the best system is the one chosen. - AdamHeard [more]
Unread 25-01-2013, 16:16
chadwick chadwick is offline
FRC #4375
chadwick is an unknown quantity at this point
Victor 888 Break/Coast Switch
What would be the best method for switching between coast and break modes on the Victor 888? We're looking at both the digital I/O option or the Switch/Servo method. How would we go about setting this up?
Unread 25-01-2013, 16:34
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
Re: Victor 888 Break/Coast Switch
Do you need to switch during the match?
Because if you don't need to switch modes on the fly you can just move the jumper on the pins.
Student (3309) 2010-2013
Mentor (597) 2014
Mentor (3309) 2013-Present
Unread 25-01-2013, 19:20
FRC #4375
We plan on switching during the match, so moving the pins wouldn't help.
Unread 25-01-2013, 19:50
You could build a tiny robot to put on your robot to change the jumper pins.
Sorry, couldn't resist.
Here's a link that might be of interest:
http://www.chiefdelphi.com/forums/sh...22&postcount=6
Unread 25-01-2013, 21:58
DonRotolo's Avatar
Back to humble
FRC #0832
In the olden days, we'd connect a digital I/O line (on the digital sidecar) to the center pin of the brake/coast 3-pin connector. Setting the pin high yielded one behavior, setting it low yielded the other behavior. I don't remember which was which, but surely you can figure it out in a minute of testing.
Use only the Signal line of the Digital I/O, not the Gnd or +5 pins
Then post the results here for the next guy, OK?
Unread 26-01-2013, 10:14
FRC #4375
We'll definitely be playing around with it! I'll post our results as soon as we have something figured out.
Unread 26-01-2013, 12:34
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
The other option is to use Jaguars on CAN, and you can change from brake to coast on the fly with your code.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 26-01-2013, 21:21
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
High is coast, low is brake.
Unread 26-01-2013, 21:40
FWIW, from the Black Jaguar Schematic Rev B.pdf
