Go to Post This web site is a service by our team to the FIRST Community to foster interest and growth in Engineering, the FIRST Competition and Education of youth for the careers of tomorrow. - Mike Martus [more]
Unread 25-01-2013, 20:54
nickhilgupta's Avatar
nickhilgupta nickhilgupta is offline
FRC #4674
nickhilgupta is an unknown quantity at this point
Is there a way to use LabVIEW to slow down the robot speed?
We have to reduce the speed because it is way to fast. So is there a way to slow it down using labview? I tried to multiply the joystick input by .5 but cant try it because we are missing a wire and wont get it for a few days. so can someone tell me if what i did in the picture (we have tank drive) with teleop.vi will work.
http://postimage.org/image/4lghy7lth/
and if it does not work, then can someone tell me what to do to slow it down?
thanks in advance.
Unread 25-01-2013, 21:01
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Re: Is there a way to use LabVIEW to slow down the robot speed?
We just discovered SquaredInputs on the motor control VI. Interesting results.
Try it.
Software Mentor
3853 Pridetronics[
Unread 25-01-2013, 21:14
If your robot drivetrain is geared so fast that your drivers cannot control full throttle, then you should seriously consider changing the gear ratio of the drivetrain.
Unread 26-01-2013, 18:04
DonRotolo's Avatar
Back to humble
FRC #0832
I agree with ether. The reason he is saying that is because slowing your speed down 50% using software means that your motors are only spinning at half their normal speed, which implies a lot less power than you could be getting. Low power is not really what you're looking for an drivetrain.
Unread 26-01-2013, 18:36
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
I agree with all the above posts...but that said, all you would have to do is multiply whatever values you're sending to the motor by 0.5 in order to limit your maximum speed from the code.
Unread 26-01-2013, 18:43
To delve a little deeper. If too fast means it accelerates too fast but isn't too fast when the joystick is pegged, then the squared inputs is a good suggestion. If too fast means that the robot's velocity is to large and the robot is uncontrollable, then you really should look at the gearing and the wheel size rather than trying to work around it in SW.
Greg McKaskle
Unread 27-01-2013, 05:52
sasha831 sasha831 is offline
Sasha
FRC #4529 (AI Robotics)
sasha831 is an unknown quantity at this point
What you are doing will work. We have a setup where we map the throttle (axis 3) to a value between 0 and 1, and then we multiply the joystick output by that value. This way, we can set the maximum speed mid game, and adjust it lower for more control, or higher if we need to push a robot out of our way
Theory is when you know everything but nothing works. Practice is everything works but no one knows why. On our Team, theory and practice are combined: nothing works and no one knows why!
