Go to Post everyone in FIRST has to do the cha cha slide at least once per season to get it out of their system. Now I can go back to doing it in the privacy of my own car (if you see a red Jeep in CT swerving back and forth don't worry, it's just me doing the slide...)! - KathieK [more]
Unread 25-01-2013, 14:16
wdburk3160 wdburk3160 is offline
AKA: William Burk
FRC #3160 (F.R.O.G.)
wdburk3160 is an unknown quantity at this point
VEX Accelerometer
I posted this in another forum, but I guess this one is more appropriate. Our team is wanting to use a VEX Accelerometer for our robot. I have looked up the specs but they are very vague. Anyone know of any detailed specs on that? And any ideas on programming it?
Unread 25-01-2013, 14:32
Re: VEX Accelerometer
Go to the VEX website http://www.vexrobotics.com
Type "accelerometer" into the yellow search box and press ENTER
Click on the link that says "VEX Analog Accelerometer Sensor"
Scroll down to the link that says "documentation" and click on that.
The very first paragraph on that page says:
The VEX Analog Accelerometer V1.0 [1] is a three-axis accelerometer that outputs an analog voltage in the range of 0V - 5V for each of three orthogonal axis (X, Y, and Z). This accelerometer is based on the LIS344ALH[2] sensor from STMicroelectronics [3].
So, try connecting the accelerometer to an analog input. LabVIEW supports analog inputs.
Just curious: what do you intend to use that accelerometer for?
Unread 25-01-2013, 19:33
beandip3160's Avatar
beandip3160 beandip3160 is offline
FRC #3160
beandip3160 is on a distinguished road
Using this website ( http://team358.org/files/programming...2009-/LabVIEW/ ) The accelerometer example that this team uses an Accelerometer Set Gain vi which as it states says that it is the volts per gravity of acceleration. It says that the information can be found on the spec sheet for the accelerometer. Is this the same as the sensitivity on the vex sheet? If it isn't then what are the gains on the vex acelerometer?
Unread 25-01-2013, 20:34
Follow these instructions:
... then scroll down to the section "Sensitivity Ranges"
Unread 25-01-2013, 20:49
FRC #3160
This is what the vex site says...
Function
Sensor Type:3-Axis Acceleration
Sensor:LIS344ALH chip
Sensitivity:±2g and ±6g
I was wondering if the sensitivity was the same thing, although the VEX accelerometer has two settings switched via jumper so I wasn't sure.
Unread 25-01-2013, 21:01
Function
This is what the document says. Look inside the red circle.
Unread 25-01-2013, 21:13
FRC #3160
Oh... I feel silly. Thank you for your help, and your patience.
Unread 25-01-2013, 21:21
You are welcome. Patience is called for as long as people are making an effort.
What are you trying to achieve with the accelerometer?
Unread 25-01-2013, 21:36
FRC #3160
Well, even after all of that effort, I think we are going to be using a gyro instead. We need to detect an angle, or to know when a specific part of our robot is going to be level or tilted.
Unread 25-01-2013, 21:45
OK :-)
I was concerned that you were going to try to double-integrate that acceleration signal.
