C++ error first defined here and line Breakpoint
We tried to make a simple drive train code for mecanums, and after we got what we think is a good end result we still end up with a first defined here and a line breakpoint error. we are kinda new to programming this year and would like any help we can get. here is the command part where the error is showing up...
#include "DriveMotorCommand.h" #include "stdio.h" #include "math.h" DriveMotorCommand: riveMotorCommand() {// Use requires() here to declare subsystem dependencies Requires(motorControlSubsystem); } // Called just before this Command runs the first time void DriveMotorCommand::Initialize() { } // Called repeatedly when this Command is scheduled to run void RobotDrive::MecanumDrive_Polar(float magnitude, float direction, float rotation) { static bool reported = false; if (!reported) { } // Normalized for full power along the Cartesian axes. magnitude = Limit(magnitude) * sqrt(2.0); // The rollers are at 45 degree angles. double dirInRad = (direction + 45.0) * 3.14159 / 180.0; double cosD = cos(dirInRad); double sinD = sin(dirInRad); double wheelSpeeds[kMaxNumberOfMotors]; wheelSpeeds[kFrontLeftMotor] = sinD * magnitude + rotation; wheelSpeeds[kFrontRightMotor] = cosD * magnitude - rotation; wheelSpeeds[kRearLeftMotor] = cosD * magnitude + rotation; wheelSpeeds[kRearRightMotor] = sinD * magnitude - rotation; Normalize(wheelSpeeds); UINT8 syncGroup = 0x80; m_frontLeftMotor->Set(wheelSpeeds[kFrontLeftMotor] * m_invertedMotors[kFrontLeftMotor] * m_maxOutput, syncGroup); m_frontRightMotor->Set(wheelSpeeds[kFrontRightMotor] * m_invertedMotors[kFrontRightMotor] * m_maxOutput, syncGroup); m_rearLeftMotor->Set(wheelSpeeds[kRearLeftMotor] * m_invertedMotors[kRearLeftMotor] * m_maxOutput, syncGroup); m_rearRightMotor->Set(wheelSpeeds[kRearRightMotor] * m_invertedMotors[kRearRightMotor] * m_maxOutput, syncGroup); CANJaguar::UpdateSyncGroup(syncGroup); m_safetyHelper->Feed(); } // Make this return true when this Command no longer needs to run execute() bool DriveMotorCommand::IsFinished() { return false; } // Called once after isFinished returns true void DriveMotorCommand::End() { motorControlSubsystem->Drive(0); } // Called when another command which requires one or more of the same // subsystems is scheduled to run void DriveMotorCommand::Interrupted() { } |
