Go to Post Do whatever you must to survive within the rules, but please stay within the rules. - Kevin Sevcik [more]
Unread 26-01-2013, 00:16
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
Shooting issues
Hii
We need help with our shooter.our shooter is not shooting high enough that we want it just go little bit and fell. we try everything to make this shooter to shoot proper distance.....but same thing....I need your help please help us .......thank u.
Unread 26-01-2013, 00:21
stryker0603 stryker0603 is offline
AKA: Jordan Smith
FRC #0314 (Megatron Oracles)
stryker0603 will become famous soon enoughstryker0603 will become famous soon enough
Re: Shooting issues
Describe the shooter please. We can't help otherwise
Unread 26-01-2013, 00:22
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Shooting issues
Details needed. Linear or curved shooter? What motors are you currently using? What wheels and what size? Are you using any gearboxes?
Unread 26-01-2013, 00:26
AKA: Akash
FRC #4684
Re: Shooting issues
This moters connected and btw we are rookies soo
Unread 26-01-2013, 00:30
AKA: Jordan Smith
Re: Shooting issues
My guess is that you aren't getting enough torque to make the speed useful or way too much compression. Have you tried 1:1 with the cims?
AKA: Akash
FRC #4684
Re: Shooting issues
Other pic is here
Unread 26-01-2013, 00:31
AKA: Akash
FRC #4684
Re: Shooting issues
Yeah we did try
Unread 26-01-2013, 00:32
AKA: Jordan Smith
Re: Shooting issues
Are the discs hitting the bolts you have holding the shooter down? Any idea on what your compression is?
Unread 26-01-2013, 00:35
AKA: Akash
FRC #4684
Re: Shooting issues
I don't think is hitting the bolts and idk about that......
Unread 26-01-2013, 00:38
AKA: Akash
FRC #4684
Re: Shooting issues
Can u give us an idea how u connect those directly to motor bec we try didn't work so we have to use gears.....
Unread 26-01-2013, 00:43
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Re: Shooting issues
I would highly recommend mounting it so that those bolts aren't there right at the exit. There's almost no way that isn't causing a problem. Try bolting through the side walls above the area discs travel through, or the top surface.
Another issue could be that your wheels aren't lining up well with the flat edge of the disc, so they aren't getting a good contact. If you can get the center of the wheel tread to touch the disc on the flat edge, you should get good results.
Also, I'm assuming you've fiddled with compression and motor speed, but if you haven't, that's step 1.
Unread 26-01-2013, 00:36
shadowjm shadowjm is offline
FRC #7777
shadowjm is an unknown quantity at this point
Re: Shooting issues
Most of the linear shooters that people are using are using an overdrive setup for their gears. It appears from your picture that you have a small gear on the motor and larger gear on the wheel which will reduce the motor output rpm. Maybe try putting a larger gear on the motor?
Regards,
John
37777
Mechanical Mentor
Unread 26-01-2013, 00:41
FRC #7777
Re: Shooting issues
Also you may need something with some grip to it on the opposite wall from the wheels. This will allow the frisbee to spin more. More spin = more stable flight
John
3777
Mechanical Mentor
Unread 26-01-2013, 00:42
FRC #7777
Re: Shooting issues
http://www.andymark.com/product-p/am-0320.htm
AKA: Akash
FRC #4684
Re: Shooting issues
Ok and other thing do we have to,have tight enough both side to throw higher frisbee.
