Go to Post Thanks, that clears things up a lot, and should probably have been obvious. - Branden Ghena [more]
Unread 26-01-2013, 00:32
stryker0603 stryker0603 is offline
AKA: Jordan Smith
FRC #0314 (Megatron Oracles)
stryker0603 will become famous soon enoughstryker0603 will become famous soon enough
Re: Shooting issues
Are the discs hitting the bolts you have holding the shooter down? Any idea on what your compression is?
Unread 26-01-2013, 00:35
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
Re: Shooting issues
I don't think is hitting the bolts and idk about that......
Unread 26-01-2013, 00:38
AKA: Akash
FRC #4684
Re: Shooting issues
Can u give us an idea how u connect those directly to motor bec we try didn't work so we have to use gears.....
Unread 26-01-2013, 00:43
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Re: Shooting issues
I would highly recommend mounting it so that those bolts aren't there right at the exit. There's almost no way that isn't causing a problem. Try bolting through the side walls above the area discs travel through, or the top surface.
Another issue could be that your wheels aren't lining up well with the flat edge of the disc, so they aren't getting a good contact. If you can get the center of the wheel tread to touch the disc on the flat edge, you should get good results.
Also, I'm assuming you've fiddled with compression and motor speed, but if you haven't, that's step 1.
