Go to Post Great people like you both [Scott and Libby Ritchie] make the FIRST community even better! - tiffany34990 [more]
Unread 25-01-2013, 13:30
Gadeer Zbedat Gadeer Zbedat is offline
FRC #1946 (Mishka Monster)
Gadeer Zbedat is an unknown quantity at this point
Jaguar configuration problem
Hiii guys , )))
I wanna ask your help !!! I've fall in a delima
How can I know if the Jaguar is working ?!!
because I doubt that some jaguars are bad !!
Unread 25-01-2013, 13:41
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Jaguar configuration problem
What is the Jaguar currently doing? What is the light on it doing when you try to run your code?
Unread 25-01-2013, 13:44
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Here is what you're looking for.
Academic Student (Forever)
Unread 26-01-2013, 11:43
but how can I know that the jaguar is working with configuring it to the Power Distribution Board???!!
Please help me !! I've stuckk in this problem ((((
Unread 26-01-2013, 11:54
Gadeer,
You will need to power the Jaguar to tell if it is working. First connect the input power to the PD and see if it will wake up. You should see the lights on the PD come on and the Jaguar fan should spin and the LED on the Jaguar will blink. If all of this is good, check PWM operation of the Jaguar. You will need to have software running with the Jaguar PWM commands. Enable and watch the LED on the Jag. You should be able to command it for forward and reverse. If it reacts normally, try connecting a motor and rerun the above tests.
