Go to Post I mean I am a pocket protector kind of guy. - techhelpbb [more]
Unread 01-26-2013, 01:07 PM
1757 1757 is offline
FRC #1757
1757 is an unknown quantity at this point
Standard java onto smartdashboard
How can I print to the smart dashboard using a standard Java program, we've already imported wpilibj.
Unread 01-26-2013, 01:46 PM
sarangmittal's Avatar
sarangmittal sarangmittal is offline
FRC #1683 (Techno Titans)
sarangmittal is an unknown quantity at this point
Re: Standard java onto smartdashboard
Import the SmartDashboard package,
 import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
And then in wherever you want to print stuff, use the putNumber() or putBoolean() or putString (look in API for all things you can put).
For example;:
double test = 4;
SmartDashboard.putNumber("Test", test);
That should automatically print the data to the SmartDashboard when you enable.
Unread 01-26-2013, 02:05 PM
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
Take a look here:
http://wpilib.screenstepslive.com/s/...-robot-program
for some examples and more directions on using SmartDashboard.
Brad
Brad Miller
Robotics Resource Center
