Go to Post No matter what you do and how well you try to protect them, some people are just out there to be candidates for the Darwin Awards! - Jay H 237 [more]
Unread 26-01-2013, 16:49
Ganondalf Ganondalf is offline
FRC #4665
Ganondalf is an unknown quantity at this point
Programming a Kill Switch
Hello, I have a switch and when I press it I want it to shut off/stop (kill switch) a motor from being able to spin in that direction. How would I program this? Also, does anyone have any examples of how to program a magnetic reed switch? I want a pneumatic cylinder to stop extending at a certain point. Thanks!
Allons-y
Unread 26-01-2013, 17:32
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Programming a Kill Switch
Not being a programmer, I can't really help you. But I can offer some advice about pneumatic cylinders. Stopping a pneumatic cylinder before the end of its stroke is not generally a good idea. Since air compresses, it will move if any load changes on it. Just be aware of that.
Unread 26-01-2013, 18:32
A recent post shows the typical LabVIEW idiom for implementing limit switches. Look at the diagram on the right half of the image attached to it. It uses the "in range and coerce" function to keep a motor from going forward if one switch is active, and to keep it from going backward if another switch is active.
Unread 27-01-2013, 02:25
FRC #4665
Fantastic! Thank you very much.
