Go to Post 1/4" baltic birch plywood is most of our metal. - z_beeblebrox [more]
Unread 24-01-2013, 18:52
Bryven Bryven is offline
FRC #2655
Bryven is an unknown quantity at this point
How to connect switches to the Driver Station
Hello,
I remember seeing a guide last year on how to wire toggle switches and other sensors to the driver-station. Does anyone know if something like that still exists? Last year we saw a team use forklift controls and some toggle switches and we'd like to mimic some of that. Ideally we want to be able to read the state of toggle switches on our driver station in order to cause our robot to perform specific actions like lighting up lights, etc.
Thanks!
Unread 25-01-2013, 01:04
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: How to connect switches to the Driver Station
You should be able to do that with Cypress FirstTouch I/O Module, that you got in the kit. Or this.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 26-01-2013, 16:17
FRC #2655
Does that board show up on the Driver Station or do we need to use different code to interface with it?
Unread 26-01-2013, 17:09
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
The cypress board is an I/O receiver which you can use in a board on the side of your driver station. This interface connects usb and communicates though programing as values or "pressed or not pressed". So you could add toggle switches to your teams driver stations. You also can create a smart dashboard to get readings and layouts on the classmates screen that you can reference while playing.
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
Unread 26-01-2013, 17:39
Nirvash's Avatar
AKA: Bryan
FRC #4676
If you have never used the I/O board I would look at this to set it up.
After you configure it, it should show up in your Dashboard like so.
Which should easily be able to be added into your code using the appropriate methods for you language. Ex. Labview
E-stop also offers a nice breakout for it, if you don't want to make your own.(Which is what I am currently trying!)
http://www.andymark.com/product-p/am-0543.htm
Unread 26-01-2013, 17:46
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Our team has disassembled a game pad and attached the connectors for potentiometers on one of the game pad's sticks to other potentiometers on an RC car pistol grip controller. The same thing could be done with buttons and switches.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
