Go to Post The size of your team has nothing to do with the size of your heart. - Amanda Morrison [more]
Unread 26-01-2013, 17:45
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: SmartDashboard can't connect to Axis Camera
Are you using a 206?
Unread 26-01-2013, 17:48
jarruda jarruda is offline
Software Engineer
AKA: Justin Arruda
FRC #1350 (Rambots)
jarruda is an unknown quantity at this point
Yes, firmware 4.40.1
Unread 26-01-2013, 18:09
Emily Horsman
Yeah, we're having similar issues. Works fine with the M1011, 206 is quite intermittent.
On our Thursday meeting we had the 206 in working order (however with some occasional connection failures), came back this morning with output cycling between "No accelerated colorspace" and connection failure.
Unread 27-01-2013, 16:00
Software Engineer
AKA: Justin Arruda
FRC #1350 (Rambots)
Ah, well this is good news then. We just ordered an M1011 to have a backup camera for competition and to test that the issue wasn't with our 206. Hopefully we will have the same experience as you and the M1011 will work consistently.
Do you happen to know if the source for WPIJavaCV + WPICameraExtension is available? I would really like to get to the bottom of its behavior with the 206. I also have reason to believe that there's a resource leak in the code as well. Running for ~20 minutes after streaming begins results in SmartDashboard crashing with a DirectByteBuffer.get call failing.
Unread 02-02-2013, 12:52
Software Engineer
AKA: Justin Arruda
FRC #1350 (Rambots)
Just to make one final post here:
We've received an M1011 camera and confirmed that the 206 is indeed a very unreliable camera for connecting to SmartDashboard. The new camera works every time that we boot up a WPICameraExtension widget.
