Go to Post Yes, an expanded FIRST will look far different than it does today. - GaryVoshol [more]
Unread 26-01-2013, 18:15
Re: Connecting to cRIO...
You don't mention what tool/language, but if using LabVIEW, make sure that the project tree item called RT compactRIO Target has the right IP address. It defaults to 10.xx.yy.02 and if you don't change it in the wizard, you will not connect. To change it, right click on the line and choose Properties and change the IP.
Greg McKaskle
