Go to Post If you're in the Chairman's Award just to win the Chairman's Award, you're doing it for all the wrong reasons. The award is there as a goal to strive for, but it shouldn't be the reason why you conduct yourself and reach out to your community and beyond the way you do. - Lil' Lavery [more]
Unread 26-01-2013, 13:45
d.kho's Avatar
d.kho d.kho is offline
AKA: Daniel Kho
FRC #2473 (CHSR)
d.kho is an unknown quantity at this point
Question RGBImage Issues
Has anyone else had an issue trying to create an RGBImage from a file? When using this code:
RGBImage* image = new RGBImage("testPattern.jpg")
I always got the error "RGBImage not declared". All of the includes are right, and WindRiver can give me the tooltips for the constructor when I hover my mouse over it. Trying to manually include the file led to some more errors though.
I ended up getting it to work by creating my own RGBImage using the nivision stuff though.
Unread 26-01-2013, 20:50
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Re: RGBImage Issues
This code will be running on the robot when it runs - don't know if that's obvious or not -- and as such, 'testPattern.jpg' must be on the robot and must be in the 'current working directory' of the running program. If you're feeling confident that all this makes sense so far, I would suggest that you try doing a little test to ensure that the file is really "there" by opening the file and reading the first 4 bytes of the file or something...if the following all checks out then I'd ask ... how are you creating this testPattern.jpg file? Could it have been saved in a different format than .jpg by a writing function? I seem to recall a situation last year where files we were writing wound up being BMP format instead of JPG due to a saving issue.
FILE* fp = fopen("testPattern.jpg", "rb");
if (fp) {
  unsigned char test[10];
  int read;
  read = fread(test, 1, 4, fp);
  if (read != 4) {
    printf("Did not read 4 bytes. Error.\n");
  else {
    printf("SUCCESS. File at least exists.\n");
else {
  printf("File not found.\n");
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 26-01-2013, 20:58
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Re: RGBImage Issues
This is a compile-time error, yes? I place this code in my compiler and it works...
Oh. You're missing a semicolon.
Try
RGBImage* image = new RGBImage("testPattern.jpg");
Instead.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 27-01-2013, 00:00
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: RGBImage Issues
if (fp) {
  int read;
  if (read != 4) {
  else {
else {
BTW, if you read and display the first 16 bytes instead of the first 4 bytes, you will see a 4-byte signature at offset 6 that will tell you if the file is a JPG or not. I believe JPG files have something like "Exif" or "JFIF" at offset 6 whereas BMP files have "BM" as the first 2 bytes of the file. There may be some other valid signatures, but you get a pretty good idea on what format the file is.
