Go to Post And yes. The Super Bowl is on, and I'm replying to a thread on Chief Delphi... - BobbyVanNess [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 26-01-2013, 21:23
twiegner twiegner is offline
FRC #2495
twiegner is on a distinguished road
Welding Urethane Belts
My team has been looking into using Urethane belts to convey the fribees. We have used poly cord which we know welds in generally the same way but it hasn't been working. We would rather not by the $688 kit to weld the belts... any tips for welding them using wood burner/soldering iron?
Unread 26-01-2013, 21:35
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Welding Urethane Belts
In 2009, we had a lot of success using a bunsen burner to heat up a steel plate (in this case, a leftover sprocket) and holding the ends on the plate until they melted before pressing them together.
https://picasaweb.google.com/1177698...77813940582290
Unread 26-01-2013, 23:11
hammerhead_399's Avatar
hammerhead_399 hammerhead_399 is offline
Team Manager
AKA: Gabriel Ruiz
FRC #0399 (Eagle Robotics)
Team Role: Driver
hammerhead_399 is an unknown quantity at this point
We use a heat gun and melt the two ends of the belt. Once they are both melted enough, we put it between a vice and clamp it together, so the two melted ends of the belt come together.
Unread 26-01-2013, 23:26
ttldomination's Avatar
Sunny
Shame on McMaster.
Seriously, the process is just, heat the ends and then push together using a flat surface. How you choose to do the two processes is dependent on your resources.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 26-01-2013, 23:30
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
What I have also done in the past is to cut the ends on an angle to get more surface area for the connection then just a straight cut. It's a little bit more difficult to weld together because you need to get the angles cut properly and then weld them neatly.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 27-01-2013, 00:38
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
To add to what he said, were trying to weld flat belt specifically. 3/8ths wide.
Unread 27-01-2013, 08:07
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
Last year our team used urethane belting for our elevator to lift the balls to our shooter. Our process was to use a propane torch to get the cut ends wet/melted, we then would press the ends together in the vee of a piece of aluminum angle. This allowed a quick alignment of the wet ends and it allowed you to press them together without them slipping.
Good Luck!
Unread 27-01-2013, 08:28
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
last year we used a high power solder gun placed the cord in a wooden 2x4 mold then melted them with the high power solder gun while pushing into the tip then removed the tip while pushing the the ends together then put the top of the mold on then finished with a clamp on it then waited 3 minutes. it worked awesome.
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 27-01-2013, 10:13
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
We have successfully welded a 1" wide belt.
We lined up the two ends in a piece of C-channel (1" I.D.)
We got a 1" x 1/8" piece of aluminum bar stock and held it vertically between the two pieces.
We heated up the bar stock and pushed the two pieces against it.
When they started to melt we pulled out the bar and pushed the two pieces together.
It worked.
Unread 27-01-2013, 13:15
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Video here: http://www.youtube.com/watch?v=auJt_...nVjw& index=4
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 27-01-2013, 20:52
blackrocks0 blackrocks0 is offline
AKA: Chaitanya Chittineni
FRC #2264 (Inceptus)
blackrocks0 is an unknown quantity at this point
Perhaps not the safest way, but i have had success with just a lighter to both ends of the connection to melt them and just pressing them together until they cooled. Be sure to wear gloves if you do this!
Unread 27-01-2013, 23:49
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
We use a heat gun and just fuse the ends together. Then, trim them clean with a pair of snips. Finally, sand the edge completely flat on a belt sander. Just don't apply too much pressure on the sander. All that you lose is the shininess on that little part of the belt.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 28-01-2013, 00:09
JCharlton's Avatar
JCharlton JCharlton is online now
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Avoid using an open flame with the urethane belt, since the fumes from burning urethane are nasty.
Instead use a heat gun - simple, clean and a heckuva lot safer.
Shield the area you don't want to melt behind a piece of wood.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 28-01-2013, 03:59
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
After welding, I like to reheat the area surrounding the join to strengthen the join and remove any air bubbles.
After that I like to use diagonal cutters and then sand the join down.
Unread 28-01-2013, 04:25
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
For small round belts, I have used a "Hot Knife For Her" from Michael's arts and crafts store.
