Go to Post We don't require innovation; we simply encourage it. - Tristan Lall [more]
Unread 27-01-2013, 03:10
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Bumper Figure 4.4
R24 B Says
hard BUMPER parts (e.g. plywood, fasteners, etc) may not extend more than 1 in. beyond the end of the FRAME PERIMETER (see Figure 4.3 and Figure 4.4)
It does not specify which direction beyond the FRAME PERIMETER. Does that mean the attached image is legal (i.e. attaching a mount on the bumpers that picks up the chassis members on the inside of the FRAME PERIMETER)?
Thanks!
-matto-
Name:	Modified Figure 4.4.jpg
Unread 27-01-2013, 03:41
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: Bumper Figure 4.4
I would say it's legal because we've used this method for a while now.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 27-01-2013, 08:12
GaryVoshol's Avatar
Cogito ergo arbitro
I concur that you should be OK. "Beyond" means outside the bounds.
This is truly a unique choice of words:
The FRAME PERIMETER, being defined as a polygon, has no end:
FRAME PERIMETER: the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the FRAME PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon.
If you look at the pictures, what they are trying to convey is that hard parts can't extend more than one inch beyond the end of the corners of the FRAME PERIMETER.
There are two corners they mark OK, with ones with the butt joint and the mitered joint. Actually the outside point of the plywood would be 1.06" from the nearest point of the FRAME PERIMETER, so that fails if they left out the word "end" in R24B.
(since 2004)
Unread 27-01-2013, 09:01
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Quote edited...
Originally Posted by aldaeron View Post
R24 B ... does not specify which direction beyond the FRAME PERIMETER. Does that mean the attached image is legal (i.e. attaching a mount on the bumpers that picks up the chassis members on the inside of the FRAME PERIMETER)?
The frame perimeter is a vertically-oriented (ie - perpendicular to a level floor supporting your robot in a natural resting state) infinitely long surface wrapped around the outside of your robot's frame, connecting all of the exterior vertices of the frame in order to form the smallest convex polygon possible (round robots have infinite vertices). There are only two directions of consequence: inside and outside. The GDC would hardly care what you do inside the frame perimeter. Therefore, the rule must be referring to the direction of "outside" the frame perimeter.
I think the key word here is "beyond" ...
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 27-01-2013, 10:54
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
We got flagged on this rule last year by another teams mentor who was a robot inspector who saw our robot early.
We had attachments that were above the bumper zone by more than an inch thus by being beyond the frame perimeter vertically since it is defined in the bumper zone of 2-10 inches
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 27-01-2013, 13:49
AKA: -matto-
FRC #1410 (Kraken)
Thanks all. I think it was just late and I was getting worried and started reading into the rules things that aren't there. Just wanted to confirm with some others.
-matto-
