Go to Post Students design and build it, the engineers/mentors are there to guide us when we stray off the path. A great way to learn, a great way to mentor, a great way to grow. - chellyzee93 [more]
Unread 26-01-2013, 10:57
MichaelTate97 MichaelTate97 is offline
FRC #1683
MichaelTate97 is an unknown quantity at this point
Team Number on Bumper
I was wondering about a discrepancy in the rule book about the Team Numbers on the Bumpers(R31). It says that the stroke size has to be 1/2 inch wide, but does not define what the stroke size actually is. To be more specific, we were going to use an '8-Bit' type font, where the corners are taken out. I was wondering if the corners were part of the stroke size, and would be violating R31, or if this is legal. Any help in interpreting this rule would be great. Thanks!
Unread 26-01-2013, 11:04
MrBasse MrBasse is online now
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Team Number on Bumper
Stroke size simply refers to the thickness of the lines that make up your numbers. As long as you meet the requirements on readability at distance and your numbers are clear and easily identifiable I doubt you'll have any problems.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 26-01-2013, 17:54
DonRotolo's Avatar
Back to humble
FRC #0832
As a robot inspector, I will check each of your characters to make sure that no part of any line is less than 1/2 inch wide. If it is you'll have to fix it before you'll pass inspection. Does that help?
Unread 26-01-2013, 21:45
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
I'll reference the Font our team provided last year:
http://www.chiefdelphi.com/media/papers/2630
This provides for a 4" font, at .75" stroke (2012 requirement and more readable) and only takes 9.5" for a four digit number and hence fits on a minimal 8" bumper section that extends to also cover the corner space (hence it is approximately 8" + 2.5" noodle + .75" plywood ~= 11.25")
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 27-01-2013, 00:53
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Following up on the OP's question (and maybe DonRotolo or someone else who's inspected can comment here). R31 doesn't seem to mandate that each digit be entirely contiguous, only that it's at least 4" tall and all line segments are at least 1/2" thick. So it seems that a font with breaks in the lines would still comply as long as it easily readable. Does that make sense?
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 27-01-2013, 09:47
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Just to make clear to MichaelTate97, the rule states
Originally Posted by R31-A
consist of numerals at least 4 in. high, at least ½ in. in stroke width, and be either white in color or outlined in white
(Bolding mine.) Which I checked because it sounded different than your question of "has to be" (meaning no more and no less). Which brings me to a possible solution. I'm assuming you're talking about a font like this. Just make the stroke width wider, so the minimum (at the corners) ends up 1/2". In the font I found above, it looks like the horizontal strokes are 2 pixels and vertical 4 pixels, so 1/4" per pixel gives you 1/2" by 1".
I have idle curiosity to dcarr's question. A team could get fancy with the font and have it pass at one competition and fail at the next -- the FRC Manual uses the word "unambiguously" which can be difficult to argue with.
Many years ago I argued with a Landlord about I couldn't make a font smaller on a storefront -- the neon connectors wouldn't fit enough to hide inside! We did it his way, and yes it was ugly. But it was his building and his rules.
Unread 27-01-2013, 10:56
kingbrandon14's Avatar
kingbrandon14 kingbrandon14 is offline
FRC 4188 Engineering Mentor
AKA: Brandon King
FRC #4188 (Columbus Space Program)
kingbrandon14 will become famous soon enough
Question Re: Team Number on Bumper
Would it be legal to also put our sponsors on the bumpers? We dont have much extra room on the robot itself this year and are wondering if thats allowed
2012 Peachtree Regional Rookie All-Star; 2015 Peachtree Regional Winner; 2016 PCH District Columbus Winner, Albany Finalist & EI; 2016 Rocket City Regional Finalist, Wildcard
Unread 27-01-2013, 11:08
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
R24 D.
The cloth must completely enclose all exterior surfaces of the wood and pool noodle material when the BUMPER is installed on the ROBOT. The fabric covering the BUMPERS must be a solid Red or Blue in color. The only markings permitted on the BUMPER fabric cover are the Team number (see Rule R31).
That would be a no
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 28-01-2013, 20:36
Migriemsl Migriemsl is offline
AKA: Marcene Grimsley
FRC #3743 (Eaglebots)
Migriemsl is an unknown quantity at this point
What kind of room do you have? If you are just wanting a place to put sponsors there are ways to work around having very little room. I have had to work with some interesting positions.
