Go to Post I won't tar and feather you, I'll disagree though. - Andrew Schreiber [more]
Unread 26-01-2013, 15:21
sarah_storer's Avatar
sarah_storer sarah_storer is offline
Georgia Tech RoboJackets Outreach
AKA: Sarah Storer
FRC #5332 (Toaster Tech)
sarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to behold
Connecting to cRIO...
our cRIO is plugged in via ethernet cable and we can ping it and get a response.
When we ran the driver station, the light by communication is green.
However, when we try to deploy code to the cRIO it says
"Failed to connect to Real-Time target"
Anything that helps is welcomed
Thanks in advance!
TEAM 3753 BULAH BOTS ALUMNI
2012-2015: Code, pneumatics, and electrical for BULAH BOTS Team 3753
2013: Bayou Regional 1st seed alliance captain and regional winners (With 118 and 4589)
2014, 2015: Bayou Regional semi-finalist
2016-?: Mentor for TOASTER TECH Team 5332
2016: Columbus District 3rd seed alliance captain, semi-finalist; Kennesaw District 3rd seed alliance 1st pick, semi-finalist; Peachtree District State Championship 4th seed alliance captain, quarter-finalist, Industrial Design Award, World Championship qualification
Unread 26-01-2013, 16:53
AKA: Sarah Storer
Re: Connecting to cRIO...
I tried again multiple times and fixed some wiring issues downstream but I still got the same error:/
Unread 26-01-2013, 18:15
You don't mention what tool/language, but if using LabVIEW, make sure that the project tree item called RT compactRIO Target has the right IP address. It defaults to 10.xx.yy.02 and if you don't change it in the wizard, you will not connect. To change it, right click on the line and choose Properties and change the IP.
Greg McKaskle
Unread 26-01-2013, 21:13
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
You also will need to set your TCP/iv4 on your computer to match your team number.
Unread 27-01-2013, 00:37
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Our team has been having issues that sound similar to this, we make a change in code and then try to deploy the update but it seems to never be able to find the crio.
We managed to find a work-around by closing the driverstation and dashboard when making changes. it seems to work about 90% of the time.
someone correct me if i'm wrong but i think it's probably some issue in the way the driverstation and dashboard get data to and from the bot.
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 27-01-2013, 11:39
You're correct enough. It's only the Dashboard communication that's causing the trouble, and it'll be fixed with an update soon. For now, your workaround is the officially sanctioned way to deal with it. The Driver Station program doesn't need to be shut down; you only have to close the Dashboard (and any other programs using the SmartDashboard data). If you do that before you try to send code to the robot, it should work every time.
Unread 27-01-2013, 14:41
AKA: Sarah Storer
Greg McKaskle
Thank you so much!! That just might be our problem! I was trying to lauch some example code from LabVIEW and the example code didn't have our cRIO IP address
I'll fix it in the morning when we get back to school
Thanks Again!
Unread 28-01-2013, 18:13
AKA: Sarah Storer
Greg McKaskle
What line are you saying to click on?
Unread 28-01-2013, 21:31
...the project tree item called RT compactRIO Target...
It's the one with the IP address in parentheses after it.
