Go to Post And if in the end the students are inspired and more of the public becomes aware of the program, and people gain more appreciation for engineering, how can that not be a good thing? - dlavery [more]
Unread 27-01-2013, 12:31
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
pic: Pyramid Problems
Unread 27-01-2013, 12:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Pyramid Problems
Had a little bit of that. Not nearly as drastic. We used some pipe clamps under the rung to hold it level, then started tacking things in place. You need to get someone (or multiple people) to hold the twist out of it while it's being tack welded. We worked from he bottom up. I wouldn't try to do the whole thing at once.
Unread 27-01-2013, 12:41
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
We use 8 packing straps attached to the top corners and adjacent lower corners and the tighten them up carefully with the ratchets. It makes the tower pretty firm.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 27-01-2013, 13:11
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Remove the chairs and step to the right. That will fix your problem.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 27-01-2013, 13:13
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Bolt the top joints together. That should fix your issue somewhat.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 27-01-2013, 13:15
nuggetsyl's Avatar
FRC #0025
There is nothing wrong with there joints. All you need to do is step right one step and remove the chairs
11 VCU winner
12 MAR Mt Olive
red is for team 348
Unread 27-01-2013, 13:16
FRC #1405
I see it corectly, we built it similar to theirs. We had the same issue. Put some bolts through the top inserts and that fixed it.
Unread 27-01-2013, 13:20
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
Cut the corners at 45 degrees instead of butting them up against each other
Unread 27-01-2013, 13:23
nuggetsyl's Avatar
FRC #0025
What bolts?
11 VCU winner
12 MAR Mt Olive
red is for team 348
Unread 27-01-2013, 13:37
karomata's Avatar
Rebellious Egyptian
AKA: Mo Elhelw
The bolts are mounted on the gusset plates, and basically what we do is drill a hole in the leg, and put a bolt through it and there is a nut welded to the gusset that holds it there, and it keeps the levels of the rungs consistant.
Happy Birthday! RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Check out this other thread for internally bolting your pyramid with mostly off-the-shelf H/W and one custom part => threaded internal sliding donut
http://www.chiefdelphi.com/forums/sh...43#post1213343
The holes in the threaded aluminum donut plug inside the rung pipe were mistakenly drilled at the 98 degree dihedral angle, instead of the correct 90 degrees, which accounts for the miter gap and the spacer stack skewing over in this initial test assembly. The nylon "curved end tube spacers" are the key to the whole concept working. We may need to glue their flat ends together with the curves rotated to the proper tube angle offset to each other to further improve joint stiffness
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 27-01-2013, 14:20
DonRotolo's Avatar
Back to humble
FRC #0832
We also had some twisty-turny stuff.
We made plywood gussets for the corners, serving the same function as the nylon spacers shown above, and that tamed the pyramid.
Unread 27-01-2013, 20:17
|DELTA|'s Avatar
|DELTA| |DELTA| is offline
Unregistered, CAD Junkie, Machinist
FRC #0997 (Spartan Robotics)
Team Role: CAD
|DELTA| is an unknown quantity at this point
We used Lots of different sized Jigs to hold things in place. also, as mentioned above, clamping under where the squares rest (to hold them up) and then measuring, tacking, measuring, cussing, cutting, and welding it up. ours turned out fine though. One thing that helped was putting a small but tall welding table in the middle and welding up things (and holding the top box up and twisting it.)
|DELTA|
Unread 27-01-2013, 20:49
kingbrandon14's Avatar
kingbrandon14 kingbrandon14 is offline
FRC 4188 Engineering Mentor
AKA: Brandon King
FRC #4188 (Columbus Space Program)
kingbrandon14 will become famous soon enough
Arrow Re: pic: Pyramid Problems
If you make a big X out of the metal pipes (not in the original design), and weld the legs diagonally to it, it shouldn't twist as much, but there may be problems with your robot driving over it, since it'd be flat on the ground...
2012 Peachtree Regional Rookie All-Star; 2015 Peachtree Regional Winner; 2016 PCH District Columbus Winner, Albany Finalist & EI; 2016 Rocket City Regional Finalist, Wildcard
Unread 28-01-2013, 11:46
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
We made a full welded pyramid and had the same problems. After a lot of struggle some local welders helped us out for free. Thanks welders!
Try Code Orange's electronics tutorials!
2015 - Tesla Division Champions
2015 - Inland Empire Engineering Inspiration Award
2015 - San Diego Regional Chairman's Award
2014 - San Diego Regional Chairman's Award
2013 - Newton Division Champions
2012 - San Diego Regional Winners
