#31
Re: How far are people shooting?
The first actual frisbee shots from the TechnoKats' frisbee shooter went about 20 feet into a mentor's hands. Consistently.
After tweaking some speeds and wheel placement, it'll regularly send frisbees the full length of the field, starting at about hip level and hitting the tarp behind the goals on a still-upward trajectory. Consistency suffers ever so slightly at that distance. I doubt that'll be the team's strategy during matches, but it's fun to see it working so well. Whether it works that well on a driveable robot remains to be seen. |
#32
We are going to go for the full court shot, probably at the larger target. Our Team developed a 3 wheel system using 2 wheels on the horizontal plane that are belted together and run direct drive off a single CIM and single wheel in the vertical plane that runs direct drive off another CIM. Top wheel is mounted slightly to left of center. Velocity is running over 30 fps and is flying flat and stable. Probably going to have to make some hefty guards for the fast spinning wheels in case of failure.
Doug http://youtu.be/i4LRvcwTFEA |
#33
45 shots into the 3 point goal, even at 75% accuracy, is over 100 points by my calculations -- you could single handedly outscore three top level climbers, even without points you could make in autonomous or climbing. It seems quite ideal, assuming your motors can hold up against 45 shots in 120 seconds. |
#34
I think 45 frisbees won't physically fit into the 3 point goal?
#35
also to not that only 1/3 feeder slots is protected
#37
I believe 2/3 are protected, and 1/3 (the one next to your opponent's 1pt goal) is unprotected.
#38
That's 31,590^3 inches for Frisbee to fall into, and assuming a Frisbee is 11 inches long and wide, and 1.4 inches tall, one Frisbee is ~169^3 inches. 45*169^3=7,623^3 inches. I could have easily made an error in my calculations, or interpretations of the field drawings, but it seems to me as if 45 Frisbees would fit into the high goal without much issue. Quote:
1) Pop a few Frisbees off before a defender comes around, and then head off to your pyramid for protected shooting, or 2) In the event your opposing alliance has a combination of immobile/shooting only/climbing only robots, use this strategy. Last edited by DanielCH : 28-01-2013 at 01:01. |
#39
We believe we will be making quick and accurate shots from around 36 feet away from the targets.
#40
We are shooting into the goals. It isn't shooting far that counts. It's scoring points.
#41
I'd be worried about 1 because the first thing I think most alliances will do will be to send a defender to block the best scorer on the opposing alliance. It may very well turn into a battle of drivetrains where the best shooter from each alliance immediately races to the feeder station and another robot from each alliance races to block them.
#42
We are using a belt. Surface speed of about 200 km/h (120mph).
#43
This idea is looking better and better. |
#44
Even a cheap, very lightweight pvc pole or two fixed at 10-12" apart and 60" high can shut down a long shooter extremely well while still giving a bot full field access. Installed for inspection, the "apparatus" could be used (or not) depending on the opponents faced in each upcoming match. Any marginally offensive robot or defensive robot should at least consider the option.
#45
we can throw the discs almost 40' with a 1-wheeld shooter prototype but our 2-wheeled prototype (that uses motors we can use on the robot) sucks - so far |
