Re: Mecanum drive problems
Are your PWM cables plugged into the same ports you specified in Begin.VI? What color are the LEDs on your Talons when you try to drive forward? Last edited by vhcook : 27-01-2013 at 14:56. Reason: better first question |
Hello and thank you for the quick reply
We worked on the bot some more this evening and detrimined that our CRio is the problem. We were getting only two wheels to run at any given time. We could switch around the pwm cables and get different wheels to run but only two at any given time. After a process if elimination we switched out the crio base unit and it worked. We have two of the wheels on the left side going the wrong direction but we think we can correct this by switching the pwm settings around ? Thanks very much |
That doesn't seem likely to be the problem. I suspect that the issue was resolved when you rewired or will show up again.
Do you have power plugged into the digital sidecar? Without power, the unit will often be able to drive a few speed controllers, but not four. Greg McKaskle |
The easiest way to fix this is to go into begin.vi and use the invert settings on the 4 Wheel Drive Open.
Thanks! |
Please tell us what the speed controller LEDs are doing when the problem occurs. Also describe the four green LEDs on the Digital Sidecar (three power indicators and the Robot Signal Light).
What you describe is vaguely consistent with the Digital Sidecar not receiving 12 volt power properly. |
| crab drive vs. mecanum drive system | superbotman | Technical Discussion | 33 | 06-01-2010 03:09 |
| Mecanum drivetrain programming problems | Mr. Freeman | Programming | 4 | 21-03-2007 17:11 |
| Mecanum problems | Ian_Xodus | General Forum | 8 | 01-02-2007 08:31 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
