Go to Post I walk through the door, and suddenly the field breaks down. It must be my magnetic personality. - Swan217 [more]
Unread 27-01-2013, 11:17
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Rectangular Target - 2013: Y Axis inverted?
I'm running the Rectangular Target - 2013 on my computer (not the cRIO) with the sample images.
The screensteps documentation (http://wpilib.screenstepslive.com/s/...ng-the-targets, the section on "Position", diagram "Aiming Coordinate System A x,y") indicates that Y=-1.0 is the bottom of the frame, but the data I am getting back is Y=-1.0 is top of the frame.
HybridLine_SmallGreen2 has two targets at (0.50625, 0.120833) and (-0.1625, 0.0583333). hmmm, the 2nd (leftmost) target looks higher in the frame to me, but has a small Y value.
I made a copy of HubridLine_SmallGreen2 with the targets almost at the top of the frame, the target coordinates change to (0.50625, -0.779167) and (-0.1625, -0.854167). Higher in the frame, but smaller Y value (almost -1.0).
Am I doing something wrong, or are the docs wrong?
Unread 27-01-2013, 11:50
Re: Rectangular Target - 2013: Y Axis inverted?
I ran the LV example, and if you click on the fourth image, it is pretty clear that Y axis has -1 at top and 1 at bottom.
Greg McKaskle
Unread 27-01-2013, 11:51
fovea1959's Avatar
AKA: Doug Wegscheid
ah. Docs are wrong. Who do we contact at WPI about that?
Unread 27-01-2013, 11:58
It is stored at WPI, but may have been written by someone from FIRST. Perhaps the best place is to file a tracker on FIRSTForge.wpi.edu.
Greg McKaskle
Unread 27-01-2013, 12:25
fovea1959's Avatar
AKA: Doug Wegscheid
I'll try, but the best fit I can find would be to file a tracker against WPILib.
It'd be good if the screensteps had a "send corrections to ...."
Unread 27-01-2013, 13:47
There were several trackers filed for screenstepslive documentation related to Java in the WPILib Java tracker on FIRSTForge. They were fixed. I'd recommend putting your comments on the LabVIEW vision documentation in the LabVIEW section in the WPILib Tracker.
Unread 27-01-2013, 14:45
fovea1959's Avatar
AKA: Doug Wegscheid
I'm not seeing a place to leave comments or any feedback. What am I missing?
http://wpilib.screenstepslive.com/s/3120/m/8731
Unread 27-01-2013, 14:57
Sorry, I realized I left out a few important words. I edited the original post. I was refereing to the LabVIEW section of the WPILib Tracker on FIRSTForge.
Unread 28-01-2013, 14:16
fovea1959's Avatar
AKA: Doug Wegscheid
...and FIRST just fixed the docs.
