Go to Post Suggesting change is one thing, implementing it is another. - JaneYoung [more]
Unread 27-01-2013, 18:25
Lightfoot26's Avatar
Lightfoot26 Lightfoot26 is offline
Just Out For A Rip, Bud...
AKA: Seth Lightfoot
FRC #1625 (Winnovation)
Lightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really nice
Need help with Labview counters
Ok, so I have a counter focused on counting 14 ticks per revolution of the wheel. My problem is these ticks continue to accumulate as the match progresses. For example... If I start at 0 and run the wheel for 1 sec, I get 140 ticks in that time. Therefore I have spun the wheel 10 revolutions, then if I run the wheel again, the counter starts from 140. I am trying to adapt this counter to find RPM.... I have boiled it down to Delta Ticks over Delta time, the math is good and everything but I am having trouble putting it all together in labview. any help is appreciated! Thanks!
Winnovation Team 1625 (2010-??)
  • Electrical/Programming Captain (2011-2013)
  • Auxiliary Driver (2012-2013)
  • Team Captain (2013)
  • Alumni (Graduated May 2013)
  • Electrical and Programming Mentor (2014-??)
Unread 27-01-2013, 18:46
Re: Need help with Labview counters
What you are doing sounds fine, but if you want to let the library do the delta for you, you can use the Reset VI. I think it would be better to keep it the way you have it and experiment with the dT that makes sense for your application.
Greg McKaskle
Unread 27-01-2013, 20:42
AKA: Seth Lightfoot
Well I am still having a bit of trouble making Labview happy... Mind writing and posting a quick vi of what you think would work? I also think running it in periodic would be more advantageous... but I can't get anything to execute in periodic.
