Go to Post What is this "off season" of which you speak? - Alan Anderson [more]
Unread 27-01-2013, 17:56
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
Using Anderson PowerPoles
Our team decided to get Anderson PowerPoles this year to improve on our electric wiring and organization.
I wanted to get the opinion of other teams who have used APP's in the past about where best and how best to utilize them, IE:
Crimping to end of motor wires?
Crimping straight to motor controllers?
Crimping to a small wire right out of PDB outlets?
Just a few ideas; I'd like to hear how you use them and maybe pictures if you can.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 27-01-2013, 18:00
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Re: Using Anderson PowerPoles
We plan on using them this year, and odds are, we're probably crimping them right to the end of the motor wires. IMO, the two most likely things to fail (that APPs could be used with) would be speed controllers and motors. If a speed controller fails, all you need to do is to unscrew terminals, remove the controller, and replace it. If a motor fails, no matter what you have to take the motors out, so it's easier to just unplug the APPs then having to replace the wire/tape it back onto the motor/solder it back on to the motor.
Unread 27-01-2013, 18:12
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
We have not used these yet but plan on doing so soon. I think we will be crimping them on every (current legal) motor in our bins, and make adapters for motors with connecters like FPs and just use the APP as our standard connector; making it easy to mix and match different motors easily.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 27-01-2013, 19:38
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
I've seen teams use them on the ends of motors... It can be pretty useful if you have to swap out a motor between matches.
We use them as an interface between any removable component. For example, the entire electrical board can be unplugged from the robot pretty quickly. Last year, our shooter was removable, so we had additional plugs between the shooter and the rest of the robot.
2016: Lake Superior WFFA
Unread 27-01-2013, 20:12
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Double check the amperage rating if attaching to your CIMs before buying/crimping.
They are very helpful, as others have noted. You can secure the APP connecting the two halves of the circuit together with a zip tie if you are afraid they might come undone (highly unlikely).
Unread 27-01-2013, 20:25
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
We tend to also use them so that the control systems folks can continue wiring things without being in the way of the mechanical people. You can wire your whole control board, put connectors on the end of the motors, and them snap the whole thing together at the end jiffy quick.
On the flip side of the coin the connectors are a major source of failure if not done properly. Make sure you give each wire a good tug after it's assembled. If the wire comes out ... well it shouldn't have. We've had more failures due to improperly crimped or assembled connectors than we have ANY other component in the electrical system.
Be sure to get the proper crimp tool for the connectors.
Unread 27-01-2013, 20:26
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
We use them for all motor connections. This will be our second or third year using them. They make a huge difference for reliability, parts replacement and cleanliness. For 2729, they are a must.
Unread 27-01-2013, 20:31
Kirill,
We have used these for many years. While we mostly use them for motors, we do use them anywhere we feel that quick removal and replacement of a module is needed. In dual motor configurations, we will assemble the blocks for four contacts so that all motor connections make at once. It is imperative that you provide some method to keep the connections from coming apart. We will either ty-wrap to chassis parts on both sides of the connection, use a ty-wrapp across the connection or we will use the actual locking block that you can obtain from APP dealers. The contacts can be made to work with #10 wire by slightly opening the body of the contact before inserting the wire. Of course using the actual crimper designed for these contacts is a must. You can obtain one from West Mountain Radio, the same place that sells the CBAIII battery analyzer.
Unread 27-01-2013, 20:40
ksafin's Avatar
AKA: Kirill Safin
Thanks for the feedback everyone.
We actually received a set of 25 Anderson Power Poles and the crimping tool that all of you are citing last year at an FTC Build-It-Day (Donated by Rockwell Collins).
We never used it for our FTC Team, but wanted to use it on our FRC bot this year so we purchased a set of 200 connections, and we already have the tool to crimp them.
Just wanted to get your feedback on the locations of where to best utilize them, and I got exactly that!
Unread 27-01-2013, 20:43
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
We crimp APPs to every motor on our robot. We have a standard pigtail length, and zip tie the APPs + pigtails in such a way to provide strain relief.
This makes swapping out failed motors very straightforward, and ensures all our spare motors will always fit, without having to rewire anything.
We do the same with our sensors by putting PWM connectors on a standard pigtail length.
At the speed controller, we do not use APPs. Instead we use standard crimp quick-disconnects in combination with these:
http://www.digikey.ca/product-search...yWords=42095-1
They make swapping out failed speed controllers a breeze - but we also usually mount one spare speed controller of each type on the board. These disconnects also make swapping a motor over to a spare motor controller very easy. We keep a few quick disconnect extension cables handy - male on one end, female on the other. In a pinch we can move a motor from a failed motor controller to the spare, and make a quick code change.
After doing this for a few years, it also makes prototyping go smoother, because all your motors and sensors a plug and play!
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 27-01-2013, 20:48
I should have added that for extra added protection we follow the crimp with solder. Yeah it is sort of like suspenders and a belt.
Unread 27-01-2013, 20:52
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
We use them everywhere - on all motors, and even things like the bridge and camera power, if we have to cover a long distance. Basically, we go:
PD board (bare wire/WAGO) -> motor controller -> APP -> motor
This makes motors easily interchangeable. We secure these connections with a zip tie during competitions rather than the roll pins as it's quicker to get them apart.
When using the APP on the bridge and camera power, we then put APP's on the plug pack as well, so we can still use wall power if we want to.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 27-01-2013, 20:53
ksafin's Avatar
AKA: Kirill Safin
Do any of you have pictures of your APP setups and uses?
Unread 27-01-2013, 21:10
AKA: Mr. Lim
http://www.chiefdelphi.com/media/img...e46e104b_l.jpg
But you've seen this already...
APPs are crimped and ziptied to 6 of 7 CIMs pictured above.
Unread 27-01-2013, 21:20
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We used them everywhere last year. There is a picture of our speed controller board in this blog post.
We're going to continue using them for motors but will be using the method that Mr. Lim and Al have suggested for speedcontrollers and other wiring. Standard pigtails and strain reliefs are very important for the motor wires. Also make some Anderson extension cables and also a Large (SB50 Battery) Anderson to Powerpole converter cable. We use the converter for quick motor tests (safer than alligator clips) and also for hooking up batteries to our new CBA (Battery analyzer)
