Go to Post I do this stuff because...well first inspired me to become me. I now understand who i am better and what i want to do. - Marygrace [more]
Unread 19-01-2003, 19:30
sinper_joe's Avatar
sinper_joe sinper_joe is offline
#0459 (Rampage Robtics)
sinper_joe is an unknown quantity at this point
Speed Controls
How many speed controls is a team allowed to use
GO 459
http://www.ehs.sbac.edu/clubs/robotics/index.html
Enginer,Builder,Human Player,Drafter in training, maybe animator
Unread 19-01-2003, 19:34
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
As many as you want/need/can afford.
They have to be Victor 884s, however. Older Victor 883s are not legal.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 19-01-2003, 21:11
Jim Giacchi's Avatar
Jim Giacchi Jim Giacchi is offline
FRC #0041 (Robo-Warriors)
Jim Giacchi will become famous soon enoughJim Giacchi will become famous soon enough
Send a message via AIM to Jim Giacchi
Also you can't use more speed controllers than you have motors for. You can use speed controllers on any motor though. Even if it says to put a relay you can put a speed controller on it instead.
Build first ask questions later.
Unread 19-01-2003, 21:15
Including the compressor. Err... well... we weren't cited for doing it, last year.
Unread 19-01-2003, 21:17
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
i think they recommend putting compressor on a speed controller, we have always done it. i think it just works better and for longer because its then on a 30A, or now even a 40A and you won't have to worry about the spike fuses
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 19-01-2003, 22:08
I don't think that it works that way. You can use a speed controller on the compressor but it needs to be on a 30A. The 40A are specifically reserved for the drill motors and chips specifically.
Unread 19-01-2003, 22:28
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
You can use as many as you want, but there are only 16 PWM outputs, so that limits how many you can independantly control.
Jeff Waegelin
Unread 19-01-2003, 23:26
Yeah, i guess but aren't you limited to one speed controller or relay per motor, so what would you use the extra ones for?
Unread 20-01-2003, 00:32
Dead weight
In the restricted hardware list, it clearly lists Speed Controller (Victor 884) : Any amount - when used with motor.
Unread 20-01-2003, 10:25
El Jefe de 148
That's some pretty expensive dead weight....
Jeff Waegelin
Unread 21-01-2003, 10:33
Nakatu
The compressors don't like starting when there is pressure in the system: They stall instead. Once they've started, 8 A is a good figure for the draw. When we had the previous controllers (in the BUD NEMA box) we placed a dump valve in the system, so the compressor always started into low pressure - and never even blew a 20 A fuse - and we could use a (supplied in the controller) relay instead of a costly motor speed controller.
I think that was 98. Many teams asked if they could use the controllers to solve the problem. It is still a valid solution.
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
speed controllers & circuit breakers deuceswild Electrical 2 15-01-2003 14:46
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
