Go to Post A good measure of Integrity is what you do when nobody's watching. - DonRotolo [more]
Unread 28-01-2013, 10:24
ohdan56's Avatar
ohdan56 ohdan56 is offline
Commander-in-Chief
FRC #4284 (Highlander Robotics Fleet)
ohdan56 is an unknown quantity at this point
Cool Joystick Turns the Bot Inverted
Basically, when we move the stick left, the robot turns right and vice versa. Forward and reverse controls are setup as desired, but we cannot figure out why the turning is inverted or what part of the code needs to be changed to meet the preferences of our driver. Please advise, thanks!
https://goo.gl/photos/8xZ9ixXRC3x14r5i7
I have not failed. I've just found 10,000 ways that won't work.
- Thomas A. Edison
DB
Unread 28-01-2013, 10:32
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
Re: Joystick Turns the Bot Inverted
I assume you have something like
robotdrive.arcadeDrive(joystick.getX(), joystick.getY());
If you change it to
robotdrive.arcadeDrive(-joystick.getX(), joystick.getY());
and it should invert your turning
Student (3309) 2010-2013
Mentor (597) 2014
Mentor (3309) 2013-Present
Unread 28-01-2013, 10:49
stingray27's Avatar
stingray27 stingray27 is offline
AKA: Michael Ray
FRC #0027 (Team RUSH)
stingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to allstingray27 is a name known to all
Or, you do not have to mess with the code at all and flip the pwm wires on your digital sidecar for your drive motor controls (Ex. flip pwm 1 and 2 if 1 and 2 are your drive pwms)
Michael Ray
Team RUSH 27
Driving Record: 93-64-0 Best Finish: Finalist (x4 FiM Districts)
Coaching Record: 16-7-0 Best Finish: Winner (Kettering Invitationa)l
Unread 28-01-2013, 11:30
Physicguy's Avatar
Physicguy Physicguy is offline
It exploded on its own I swear...
AKA: Jeffin James
FRC #2582 (Pantherbots)
Physicguy is just really nicePhysicguy is just really nicePhysicguy is just really nicePhysicguy is just really nice
Last year my team had the same problem and this was our solution given by our programming team lead... "let just flip the joystick"... i thought it was funny and i wanting to share.
Unread 28-01-2013, 11:46
Carefully inspect both your code and your wiring. Make sure that the left and right motors are the same ones in both the software and the hardware. It sounds like one of them has the sides swapped.
