Go to Post It's about compressing life into 6 weeks. It's about doing. It's about learning to fail. It's about gracious professionalism. It's about releasing the limitations that we all put on ourselves. It's about thinking outside of the box. It's about growing. - JohnBoucher [more]
  #31   Spotlight this post!
Unread 26-01-2013, 19:14
Re: How far are people shooting?
The first actual frisbee shots from the TechnoKats' frisbee shooter went about 20 feet into a mentor's hands. Consistently.
After tweaking some speeds and wheel placement, it'll regularly send frisbees the full length of the field, starting at about hip level and hitting the tarp behind the goals on a still-upward trajectory. Consistency suffers ever so slightly at that distance. I doubt that'll be the team's strategy during matches, but it's fun to see it working so well.
Whether it works that well on a driveable robot remains to be seen.
  #32   Spotlight this post!
Unread 27-01-2013, 13:27
dchartley dchartley is offline
FRC #3684
dchartley will become famous soon enough
We are going to go for the full court shot, probably at the larger target. Our Team developed a 3 wheel system using 2 wheels on the horizontal plane that are belted together and run direct drive off a single CIM and single wheel in the vertical plane that runs direct drive off another CIM. Top wheel is mounted slightly to left of center. Velocity is running over 30 fps and is flying flat and stable. Probably going to have to make some hefty guards for the fast spinning wheels in case of failure.
Doug
http://youtu.be/i4LRvcwTFEA
  #33   Spotlight this post!
Unread 28-01-2013, 00:17
DanielCH's Avatar
DanielCH DanielCH is offline
FRC #0295 (Renevatio)
Team Role: Driver
DanielCH is an unknown quantity at this point
If it's not confidential, would you mind explaining why that wouldn't be your primary strategy during a match?
45 shots into the 3 point goal, even at 75% accuracy, is over 100 points by my calculations -- you could single handedly outscore three top level climbers, even without points you could make in autonomous or climbing.
It seems quite ideal, assuming your motors can hold up against 45 shots in 120 seconds.
  #34   Spotlight this post!
Unread 28-01-2013, 00:26
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I think 45 frisbees won't physically fit into the 3 point goal?
  #35   Spotlight this post!
Unread 28-01-2013, 00:34
FRC #1836 (MilkenKnights)
If somebody can do this while trying to shoot over an 84" tall robot 3 feet away I will be impressed. Remember it only takes 1 small pole in front of that shooter to mess up that strategy.
  #36   Spotlight this post!
Unread 28-01-2013, 00:37
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
also to not that only 1/3 feeder slots is protected
  #37   Spotlight this post!
Unread 28-01-2013, 00:50
Andrew Lawrence
Posts: n/a
I believe 2/3 are protected, and 1/3 (the one next to your opponent's 1pt goal) is unprotected.
  #38   Spotlight this post!
Unread 28-01-2013, 00:57
DanielCH's Avatar
Team Role: Driver
How do you figure that? I'm not sure, but at this field drawing, page 69/146, it appears that the high goal has a bin that is 26 inches down, 54 inches across, and 22.5 inches deep below the gap for the goal.
That's 31,590^3 inches for Frisbee to fall into, and assuming a Frisbee is 11 inches long and wide, and 1.4 inches tall, one Frisbee is ~169^3 inches. 45*169^3=7,623^3 inches.
I could have easily made an error in my calculations, or interpretations of the field drawings, but it seems to me as if 45 Frisbees would fit into the high goal without much issue.
That's definitely something to take into consideration, and a strategy my team is considering employing as a backup tactic, but if you could either
1) Pop a few Frisbees off before a defender comes around, and then head off to your pyramid for protected shooting, or
2) In the event your opposing alliance has a combination of immobile/shooting only/climbing only robots, use this strategy.
  #39   Spotlight this post!
Unread 28-01-2013, 01:01
Andrew Lawrence
Posts: n/a
We believe we will be making quick and accurate shots from around 36 feet away from the targets.
  #40   Spotlight this post!
Unread 28-01-2013, 01:18
DampRobot's Avatar
Physics Major
AKA: Roger Romani
We are shooting into the goals. It isn't shooting far that counts. It's scoring points.
-Plutarch
  #41   Spotlight this post!
Unread 28-01-2013, 01:39
I'd be worried about 1 because the first thing I think most alliances will do will be to send a defender to block the best scorer on the opposing alliance. It may very well turn into a battle of drivetrains where the best shooter from each alliance immediately races to the feeder station and another robot from each alliance races to block them.
  #42   Spotlight this post!
Unread 28-01-2013, 12:16
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Originally Posted by DonRotolo View Post
No wheels? Care to elaborate? Sounds fascinating.
We are using a belt. Surface speed of about 200 km/h (120mph).
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
  #43   Spotlight this post!
Unread 28-01-2013, 12:46
MrForbes's Avatar
AKA: Jim
It looks like you're right, thanks.
This idea is looking better and better.
  #44   Spotlight this post!
Unread 28-01-2013, 13:25
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Even a cheap, very lightweight pvc pole or two fixed at 10-12" apart and 60" high can shut down a long shooter extremely well while still giving a bot full field access. Installed for inspection, the "apparatus" could be used (or not) depending on the opponents faced in each upcoming match. Any marginally offensive robot or defensive robot should at least consider the option.
"A genius is just a talented person who does his homework" T. Edison
  #45   Spotlight this post!
Unread 28-01-2013, 14:09
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
great idea!
we can throw the discs almost 40' with a 1-wheeld shooter prototype but our 2-wheeled prototype (that uses motors we can use on the robot) sucks - so far
