Go to Post The difference between a robotics kid and a generic nerd. Both use their calculators for statistical analysis. One keeps it a closely guarded secret, the other brags about it on Chief Delphi! - Kevin Leonard [more]
Unread 28-01-2013, 10:41
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Unable to get axis camera feed on smartdashboard
Im having trouble viewing the camera feed on the smartdashboard. I have added the camera image, but cannot get a video feed to it.
I am using the standalone dashboard version 1.0.4.
I can view the feed in a browser without any issues, I can do image processing onboard the cRIO, and I can view the feed with the default/LabView dashboard. So, it isn't a connection or hookup issue. To get the dash to work, I have tried different FPS/Resolution settings, only one of which worked, the default size and 30 FPS. After rebooting everything, however, it again refused to connect.
Basically, everything works perfect with the camera except the C++ SmartDashboard.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 28-01-2013, 15:57
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Unable to get axis camera feed on smartdashboard
There are a number of possible things that you might do to fix the problem. Check this URL:
http://Wpilib.screenstepslive.com/s/3120/m/7932/l/93058
for some tips on getting the camera plug-in going. Make sure you read the page to the bottom, there are some troubleshooting suggestions there.
Brad
Brad Miller
Robotics Resource Center
