Go to Post FRC is about giving students the best experience possible. - MikeE [more]
Unread 28-01-2013, 16:02
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Power Distribution Board visibility for inspection
Post a picture of the current electronics set up.
Field personnel really need to have easy crio, radio, and main breaker accessibility. Safety is also a significant issue behind this rule.
Also if you plan on hanging, and having anything in zone 3, (even if its a 1/4" of aluminum) make sure you can turn the robot off from the ground easily.
Unread 28-01-2013, 16:15
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Our PD board was pretty obscured last year (we put it vertically behind our collection mechanism) and Big Al gave us a talking to at Champs. It's unlikely they won't pass you because of that considering the amount of work it would take to relocate something the magnitude of the PD board but I can guarantee you the inspectors won't be happy about it. Remember, they say it must be visible for inspection, not visible for gameplay so if you choose to have it mounted on some sort of hinged mechanism it is still legal.
Unread 28-01-2013, 16:23
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Main breaker, cRIO, and radio are easily accessible. Will get a pic after work
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 28-01-2013, 20:42
DonRotolo's Avatar
Back to humble
FRC #0832
As Grim Tuesday noted, as an inspector I would be unhappy with that, but eventually I would pass it. Good luck changing out a wire or breaker in a hurry!
Unread 29-01-2013, 17:34
Negative 9 Negative 9 is offline
FRC #0611
Negative 9 is an unknown quantity at this point
Do you guys think it would be fine to mount the PDB on the underside of the robot? When the robot is flipped it would be easy to see for inspection.
Unread 29-01-2013, 17:48
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Legal? Yes. Smart? No. As your robot bounces and hit things, the breakers could fall out if its mounted upside down.
2016: Lake Superior WFFA
Unread 29-01-2013, 17:53
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Remember that although the slots have a pretty good grip, the only thing holding the breakers in is friction, and in that orientation gravity is working against you.
Also, ground clearance might be an issue depending on your setup. I'd hate to see you smash the PDB into the bump around the pyramids (or snag wiring on a frisbee you've run over).
Unread 28-01-2013, 21:05
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Please do. From what it looks like in that pic, the main breaker isn't very accessable and might need to be moved. To answer your original question, I'd be very unhappy if I had to inspect that PDB location. I'm sure it'd take more time than either of us would like to finish.
But chiming in as a team member...why would you do that to yourselves? I can almost guarantee that you're going to regret that location during some point in the season.
Mentor http://www.teamtitanium.org/
