Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. But crazy ideas tend to produce some excellent results. - Yipyapper [more]
Unread 28-01-2013, 17:25
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Best way to measure period between pulses? Counters and FPGA
Originally Posted by Ken Streeter View Post
Below is the definition for the ShooterWheelTask, of which the "run" method will be executed every 20 milliseconds. This code computed the wheel RPM by dividing the number of counts observed since the last invocation by the elapsed time since the last invocation, with appropriate unit conversions.
This is "method 1" above. This is what he claims not to want.
Time was measured using the FPGATimestamp, which has a resolution of approximately 6.5usec.
This is inaccurate. The FPGATimestamp itself has a resolution of 1 us. The digital I/O that it timestamps (in the case of digital interrupts or encoder pulse measurements, etc.) is 6.525 us.
Cheers,
-Joe
Unread 28-01-2013, 17:50
Originally Posted by Mr. Lim View Post
public double getPeriod() {
        double period;
        if (m_counter.readTimerOutput_Stalled()) {
            return Double.POSITIVE_INFINITY;
        } else {
            period = (double) m_counter.readTimerOutput_Period() / (double) m_counter.readTimerOutput_Count();
        return period / 1.0e6;
Something isn't jiving here. In the above code, why would you take the period and divide by the count? If the FPGA is measuring the period directly, should we just be taking the period directly? Will count ever be anything other than 1?
The variables are not terribly verbose... the "count" is the number of samples in the sliding window average. Count will always be 1 if you specify not to average (NumberOfSamplesToAverage = 1).
The FPGA does not like to divide without using up a bunch of gates, where and the RT CPU with an FPU has no problem doing this. This is an optimization where all the addition and synchronization is done in hardware where it needs to be done, but the divide operation to get the actual average period is pushed to the driver.
If you want "Method 1", you have to do it the way Ken Streeter described. If you want "Method 2", you must use the FPGA.
Cheers,
-Joe
Unread 28-01-2013, 17:53
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Thanks for the correction, Joe! I'll edit my post above to fix it!
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 28-01-2013, 17:58
We had a Counter set up exactly as you describe above. The periods we were getting had a very pronounced stepwise response. As a result, our RPM readings changed in increments of about 375 RPM.
There is a finite resolution on the timing of the pulses. That period is 6.525 us per edge. In your system, does that correspond to 375 RPM? You may want to turn on averaging to improve the resolution (but increase the latency).
We did the math, and these increments corresponded with 1 count / 20ms, which led us to believe the reads were still being done via method 1.
Sounds like a coincidence, maybe? Where are you getting 20ms as the refresh period? Just because that's the Driver Station's packet rate?
Is it possible that the other modes (other than semi-period) use the FPGA to count pulses over a 20ms period instead of measuring the time between pulses directly?
No. The FPGA only implements method 2.
Unread 28-01-2013, 18:02
Originally Posted by Joe Ross View Post
The FPGA doesn't return floating point values, so the period isn't in units you can use directly. Presumably, the Period is actually the period in clock cycles, and the count is the number of clock cycles per second. Dividing those two gives you a period in seconds.
Close. The "period" is in microseconds. The "count" is the number of samples accumulated by the averaging engine. The code also divides by 1.0e6 before returning to give the required "seconds" unit.
Unread 28-01-2013, 18:28
I had missed that in the original post. However, now I understand why the original poster doesn't want to use "Method 1." Given the statement of seeing RPM values with a resolution of 375 RPM and a hypothesized 20ms sampling period, their system must be using a wheel that has only 8 counts per revolution. In order to get greater RPM measurement resolution while keeping their 8 CPR sensor, they would need to have a longer sampling interval (longer than 20ms).
Similarly, with a 250 CPR sensor such as 1519 used in 2012, our computed RPM values are discretized at units of 12RPM. Measuring wheel speed to the nearest multiple of 12RPM was fine for our wheel shooter last year. Measuring to the nearest 375RPM might be troublesome.
Unread 28-01-2013, 20:29
DrakusDarkus's Avatar
DrakusDarkus DrakusDarkus is offline
Learning something new, every day!
AKA: Alex S.
FRC #1987 (Broncobots)
DrakusDarkus is an unknown quantity at this point
As described in another post, hidden in the LabVIEW programming forum (even though we were doing this in Java), Team 1519 had success last year using the Encoder object at 1X sampling to count pulses from a USDigital E7P encoder with a 250CPR optical wheel spinning at around 4000RPM. However, we performed our RPM computation in a different manner than using the built-in functions. We found our approach to give excellent accuracy. This same strategy should work just fine for a Counter object.
First off, we set up a separate task in Java to periodically compute the RPM of our shooter wheels. (This task also will control the motor for the wheels, too.) Below is a code excerpt showing how to set this up:
    private Encoder wheelEncoder = new Encoder(RobotMap.SHOOTER_WHEEL_ENCODER_A, RobotMap.SHOOTER_WHEEL_ENCODER_B, false, CounterBase.EncodingType.k1X);
    private static final long WHEEL_SPEED_PERIOD = 20; // milliseconds
    timer = new java.util.Timer();
    timer.scheduleAtFixedRate(new ShooterWheelTask(), 10000, WHEEL_SPEED_PERIOD);
Below is the definition for the ShooterWheelTask, of which the "run" method will be executed every 20 milliseconds. This code computed the wheel RPM by dividing the number of counts observed since the last invocation by the elapsed time since the last invocation, with appropriate unit conversions. Time was measured using the FPGATimestamp, which has a resolution of approximately 6.5usec 1usec. (Edit: updated resolution per jhersh posting, below.) We then compared the measured RPM against the desired RPM, and used a "Bang - Bang" controller to set the wheel speed. This simplistic approach worked incredibly well. We plan to use it again this year.
We can't take the credit for the "Bang - Bang" controller application -- lengthy CD discussions on this last year led to Ether's white paper on the subject.
Below is a snippet of our "ShooterWheelTask" code. Various declarations of variables are not in this code snippet, but I think you'll be able to figure out what they are from the context.
PS: See you at GSR, Mr. Lim!
    private class ShooterWheelTask extends java.util.TimerTask {
        public void run() {
            double power;
            double now = Timer.getFPGATimestamp();
            int count = wheelEncoder.get();
            wheelEncoder.reset();
            // NOTE:  60 seconds per minute;   250 counts per rotation
            actualWheelSpeed = (60.0 / 250.0) * count / (now - prevWheelTime);
            prevWheelTime = now;
            if (actualWheelSpeed >= wheelSpeed) {
                power = 0;
            } else {
                power = 1;
            if (automatic) {
                setWheelJag(power);
            else {
                setWheelJag(0);
Thanks, we will try utilizing this in some way because we are having similar problems
-Alex S.
Programmer on the Broncobots (Team 1987)
Unread 28-01-2013, 20:52
Joe,
How is this implemented under the hood in FPGA? Is there a ring buffer in the FPGA which the FPGA populates with the 6.525us_resolution_timestamp for each rising edge it detects (assuming it's not in semi-period mode), and then when requested retrieves the elapsed time between the N+1 most recent samples in the ring (which the cRIO CPU then divides by N)?
How large can "NumberOfSamplesToAverage" be? I searched the 2012 C++ and the 2013 Java WPILib code but couldn't find that search string.
EDIT:
@all:
I attached a small Excel app that computes the RPM jitter caused by the 6.525us timing resolution of the edge detections. There will be additional jitter due to manufacturing tolerances in the physical locations of the edges in the sensor, but I've not included those here.
Note how large the jitter is with a 360 PPR sensor at 5000 RPM with averaging set to 1. If you set the averaging to 120 (1/3 revolution) you can reduce the jitter dramatically, at the cost of some phase lag in the signal.
If you make a 1 PPR sensor with averaging set to 1 you'll be able to get an updated reading every 12ms at 5000 RPM with very low jitter.
Last edited by Ether : 29-01-2013 at 14:53. Reason: revising jitter computation to better model quantization
Unread 28-01-2013, 22:41
There is a buffer that will hold up to 127 samples for each counter / encoder. It has write pointer that does form a ring buffer. The sum of the samples between the write pointer - average_size (usually) and write pointer are summed every 0.1 us * average_size (yeah I know... overkill) and made available to the driver (i.e. not on demand) along with the number of samples available. When a counter is reset, the write pointer is moved to mark all samples unwritten (so the "count" returned would be 0).
The I/O is 6.525 us from sample to sample. The timer used has a 1 us resolution. So the actual resolution is 6..7 us. However, the error is not cumulative across the average. Regardless of the number of samples averaged, the error is less than 7.525 us.
The FPGA interface function is called writeTimerConfig_AverageSize(). Looks like we never exposed that to the WPILib API layer in C++ (and therefore Java). It's exposed in LabVIEW.
Cheers,
-Joe
Unread 29-01-2013, 00:52
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
And I was sitting in this discussion wondering how nobody knows that you can configure the hardware averaging. It's a register in the FPGA's counter/encoder timer config register, exposed by the Set Timer functions, and is very useful.
Our 2012 robot (with a 4-line handmade aluminum and gaffers tape disc) averaged 12 samples (three whole rotations) to get a perfect signal with ~2.5rpm minimum step. If I set the graph to autosize I could see the controller oscillate between exactly one step above or below the target speed, when steady state.
Kettering Motorsports
Unread 29-01-2013, 01:10
What source code file would that be in? I cannot find it.
It's not in the 2012 C++ WPILib source rev3111 timer.cpp
Unread 29-01-2013, 01:13
Encoder.cpp and Counter.cpp
Unread 29-01-2013, 01:18
OK, so we're talking about modifying and re-compiling the WPILib source, not simply passing a parameter?
Unread 29-01-2013, 01:23
That is what I was saying. It is not in the WPILib API layer in C++ and Java. That means if you care to use the hardware feature, you need to move down a layer.
Cheers,
-Joe
Unread 29-01-2013, 01:42
Got it.
