Re: Inventor tutorials
Matthew,
Please check my blog. The Assemblies tab contains links to 2 videos. Assembling the Base Chassis Part 1 of 2 Assembling the Base Chassis Part 2 of 2 If you cannot access them please email me directly and I will forward them to you. Also, for the Built By Design video data sets. I should have access to them, so let me know what you need. I will be posting a second webinar later this week, check the FIRST email blast for details. |
I am working through your first video and I'm stuck on the step to create the 23" C channel. I figured out how to create the offset work plane, but when I use the split command, OK and Apply are greyed out in the split dialog. What am I doing wrong? Thanks, Matt.
Matthew,
Here is a link to another thread with a video showing the work flow for work plane and split. This is for a STEP file, but the work flow is the same. http://www.chiefdelphi.com/forums/sh...d.php?t=111663 Scroll close to the bottom for my post with the attached zip file. |
