Go to Post I want to take a moment to thank every single FIRST mentor on behalf of all the FIRSTers (students) out there, for giving us the best we can get. - Arefin Bari [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 28-01-2013, 08:54
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
Re: Welding Urethane Belts
We used belts for picking up the balls last season and using them again this year. The easiest way we find it to use a heat gun (WEAR GLOVES!!) and heat up the two ends and press together. It usually works pretty well.
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
Unread 28-01-2013, 19:20
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
We have heated a strip of sheet metal (held with Vice Grips) with a propane or MAPP gas torch and pressed the ends of the belt onto each side of the sheet metal and then pulled the sheet metal away letting the ends touch and fuse together. Took several tries to get the heat timing right but worked well.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 28-01-2013, 19:23
Jared Russell's Avatar
Taking a year (mostly) off
We use a hot air gun and a small jig made out of C channel (1" ID) and square tubing (1" OD). Put one end of the belt in the C channel (with a 1" wide belt, it should be a snug fit). Overlap the other end of the belt by about an inch. Use the heat gun and heat both pieces of belt. Once hot enough, press the joint with the piece of square tubing. Once you figure out the technique (heat setting, distance from workpiece, time) for softening the belts, you will get a perfect weld every time. You do NOT want the belts to start to bubble.
