Go to Post Canadians just have to mess everything up. - ATannahill [more]
Unread 26-01-2013, 20:17
dhe95 dhe95 is offline
FRC #2637 (Panthers)
dhe95 is an unknown quantity at this point
Camera Extension not appearing in SmartDashboard
Our team is trying to write our own custom image processing extension for SmartDashboard but whenever we compile and move the .jar to the extensions folder, nothing shows up in the add menu.
Here is the code we are using
import edu.wpi.first.smartdashboard.camera.WPICameraExtension;
import edu.wpi.first.wpijavacv.WPIColorImage;
import edu.wpi.first.wpijavacv.WPIImage;
public class VisionSystem extends WPICameraExtension {
    @Override
    public WPIImage processImage(WPIColorImage rawImage) {
        return rawImage.getRedChannel();
Any suggestions?
Unread 26-01-2013, 23:54
Johnbot's Avatar
Johnbot Johnbot is offline
Es Brokein!
AKA: John Westhoff
FRC #4791 (Pandroids)
Johnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really niceJohnbot is just really nice
Re: Camera Extension not appearing in SmartDashboard
We had a similar problem. We just re-installed the SmartDashboard from FIRSTForge and used its extensions folder and its jar, and everything was fine afterwards.
2011-2014 - FRC 2607 - Student
2012-2012 - FLL 2249 - Coach
2015- ???? - FRC 4791 - Mentor
Unread 27-01-2013, 15:33
We tried that and it still doesn't show up. Could it be because it extends WPICameraExtension and not StaticWidget?
Unread 28-01-2013, 19:49
Johnbot's Avatar
Es Brokein!
AKA: John Westhoff
No, it should be WPICameraExtension if you want it to display the camera image.
Are you sure you are putting your jar in the extensions folder in C:\Program Files\Smart Dashboard, and that you are running the exe in that folder?
Unread 28-01-2013, 22:36
Yes, our extensions folder contains WPICameraExtension.jar and our vision jar file. It also includes a folder named lib which contains javacpp.jar, javacv.jar, javacv-windows-x86.jar, and WPIJavaCV.jar
In the view->Add menu, the extensions that show up are Image, Connection Indicator, Label, Robot Preferences, Camera, and Laptop Camera
EDIT: We got it to work by running SmartDashboard through command prompt. Just set directory to SmartDashboard and run
java -jar smartdashboard.jar
