Re: SmartDashboard not connecting?
I'll try that exact code when I get in tomorrow.
I know that I have the IP address configured correctly on the Driver Station, and I entered "23" when asked for my team number for the SmartDashboard. I have no problems connecting to the robot in any other regard. Curiously, I do not have a `~/sunspotfrcsdk/tools/` folder, although I do have other folders in `~/sunspotfrcsdk`. Do you know what installation creates that folder, as I might be missing that. I have installed Java, NetBeans, the 6 NetBeans Plugins (from the xml file hosted by WPI), and the most recent SmartDashboard Installer from this page |
Can I get any other opinions on this? I'm a remote programming mentor this year, and can help them with programming concepts, but rely on the students to get the tools installed. What is supposed to be in this tools folder? Can someone doing java post a screenshot?
Thanks! |
If you use the 2013 Smart Dashboard with a robot with 2012 java, it will not connect. Alternately, if you downloaded Smart Dashboard 1.02 from that page, and use it with a robot with 2013 java, it won't connect. What was the result of testing Brad's suggestions? |
[SOLVED] SmartDashboard not connecting?
Thanks to your help I now have all the tools (which were installed when I fixed the problem, and I suspect my code will work now)
It turns out that the NetBeans plugin xml file linked to by the "Getting Started" PDF I'm using is for 2012. If anyone reading this (now or in the future) has any sway with the Java NetBeans Plugins, I suggest putting the build season year in the URL for the plugins. |
I have been experiencing the same problem, but while we have yet to run the test program, I have followed all of these steps. Any suggestions?
Double check that your NetBeans Plugin URL is http://first.wpi.edu/FRC/java/netbea...se/updates.xml (note how it ends in `update/Release/updates.xml`, Last year's (2012) plugins ended in `update/updates.xml`)
That was the problem for me. |
