Go to Post As far as I am concerned, the quality of an electronic device is directly proportional to the number of blinky lights on it. - EricVanWyk [more]
Unread 28-01-2013, 22:09
AZDevilRobot AZDevilRobot is offline
FRC #4111 (Some Assembly Required)
AZDevilRobot is an unknown quantity at this point
Window Motor Gear Problem
Hi everyone
For my team's disc shooter, we were thinking of using a gear system to angle our shooter. A 72 tooth gear would be attached to the shooter and a 14 tooth gear would be spun by a window motor and turn the big gear. The problem is, the small gear we have has a hex shape hole and won't fit on the window motor because of the shape and because its too big. Do we have to buy a gear specifically for the motor or is there something we can do so the gear will fit?
Thanks for the help
Team 4111
Unread 28-01-2013, 23:16
Mugurussa675 Mugurussa675 is offline
FRC #0675
Team Role: Driver
Mugurussa675 is on a distinguished road
Re: Window Motor Gear Problem
Originally Posted by AZDevilRobot View Post
Hi everyone
Thanks for the help
Team 4111
You have to either buy a gear to fir around the window motor, or you can machine/order a hub that fits around the window motor and that the gear mounts to.
FRC Team 675
Drive team
Team Leader
Manufacturing Leader
Unread 28-01-2013, 23:57
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
The KoP includes to adapters to convert the window motors in the kit to a keyed shaft. (See KoP checklist page 3) I believe it is a 5/8ths shaft, but I am not sure. Remember that if your shaft has a large OD, you can always drill out the inside to shave off a lot of weight, depending on the stress on the shaft. You could, as we have done before, adapt these collars to the plastic gears included in the Fisher Price gearboxes from past years. Unfortunately, we didn't receive these this year, but I'm sure that if you don't have one, a local team will. I know we have a stockpile of about 15 to 20 of them.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 29-01-2013, 00:04
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Hi everyone
Thanks for the help
Team 4111
You are allowed to modify the little plastic piece on the window motor. We grinded it off one year and pressed a sprocket onto it.
Now and days though we just laser out a custom plate-gear with the "shape" of the window motor output piece and press them on. Easy is you have the resources.
