Go to Post To me, the changing rules are a big part of the fun. If the rules stayed the same year to year, robots would start to look the same. That would be boring. - Richard Wallace [more]
Unread 29-01-2013, 00:22
Arkamond Arkamond is offline
FRC #3102
Arkamond is an unknown quantity at this point
Quick Solenoid question to clear up inconsistencies.
Details:
CRIO: NI FRC-cRIO II (4 slot) (Connected to VC 24v mainboard power)
Analog Breakout Board Connected to 20-amp Snap-Back
Digital Breakout Board
Pneumatic Breakout Board Connected to 20-amp Snap-Back
24V Solenoid (Dual connected to Pneumatic Breakout Board)
*120 PSI stored, 58 going out to Solenoid actively.
We just got our new cRIO today (as our old one was 5 years old.)
and we wired everything up to that, although wiring from the original cRIO was so that the 24v mainboard that now goes directly to the cRIO, also went to the pneumatic boards power. But now each Breakout Board has their own 20-amp Snap-Action breaker.
The issue is, the Solenoids light up like how they did on the old cRIO, but they don't move any air anymore. The lights correctly correspond to button clicks, but no air is moved at all, not a budge.
I've heard this is a common problem, but haven't seen any ways to provide a clean fix.
Thanks
Unread 29-01-2013, 00:34
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
I may be interpreting you wrong but if you are using a 24volt solenoid you need to power the breakout from the 24 volt connector on the power distribution board. It won't fire if you are just giving it 12 volts via a 20amp breaker.
At least this is how it was one in prior years.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 29-01-2013, 00:39
FRC #3102
Re: Quick Solenoid question to clear up inconsistencies.
But wouldn't that take power from the cRIO? There's only 1 24v slot.
Unread 29-01-2013, 00:46
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
If I remember correctly, the connector for the 24 volt area on the power distribution board goes V, C, NC, C (I don't have it next to me, I believe that's how it goes.) Hook your cRIO into the V and the C as you normally would, but then use the NC and remaining C to power your solenoid breakout. The cRIO will operate at a minimum of 9 volts (assuming you have the FRC cRIO II), but I wouldn't worry about the power draw against it.
I'm right 90% of the time, so why worry about the other 3%?
Unread 29-01-2013, 00:52
College Mentor
AKA: Trent Borman
On this page they reference supplying it with 24 volts:
http://wpilib.screenstepslive.com/s/...dware-overview
Oddly, despite having FIRST choice options for 24V solenoids as well as having them in the rookie kit, they do not have a diagram for how to wire for 24V solenoids.
Here is the diagram from 2012:
I would suggest submitting a Q&A question about it to confirm that this is the proper procedure.
