Go to Post Place a corner of it on the end of a table, clamp down the other side, and have a good whack at it with a hammer (hard). If it didn't break, it was polycarbonate. - vivek16 [more]
  #46   Spotlight this post!
Unread 28-01-2013, 16:46
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Re: How far are people shooting?
Originally Posted by Andrew Lawrence View Post
I believe 2/3 are protected, and 1/3 (the one next to your opponent's 1pt goal) is unprotected.
But that doesn't matter, because you can put your 45 discs at any of the three stations in any configuration as you please (see Q&A).
  #47   Spotlight this post!
Unread 28-01-2013, 17:18
darkember darkember is offline
AKA: Billy
FRC #0375 (Robotic Plague)
darkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of light
I have a feeling that we are going to see a lot of full court shooters so im gonna also agree on the stock for 84" tall defense robots to be really high.
  #48   Spotlight this post!
Unread 29-01-2013, 01:24
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
We've finally gotten our hopper-to-shooter prototype up and running and are moving full-swing on to CADding the sheet-metal version. We fired it up today:
http://www.youtube.com/watch?v=MCHPkhigkks
Linear shooter, mini-CIM on first wheel, CIM on second, with AM pneumatic wheels. Estimated 30-40 foot travel at about 40%/60% on the two wheels, respectively, at 15-20 degrees. Definitely looking optimistic at this point! Thanks to all the teams that posted success with the paint buckets, can't beat $3 essential robot parts
  #49   Spotlight this post!
Unread 29-01-2013, 02:32
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
We are going for the back of the pyramid , we would like to make shots consistently from 13' to 25' straight line distance from the 3-goal.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
  #50   Spotlight this post!
Unread 29-01-2013, 10:15
TheCrayButton's Avatar
TheCrayButton TheCrayButton is offline
FRC #3528
TheCrayButton has a spectacular aura aboutTheCrayButton has a spectacular aura about
Originally Posted by dchartley View Post
We are going to go for the full court shot, probably at the larger target. Our Team developed a 3 wheel system using 2 wheels on the horizontal plane that are belted together and run direct drive off a single CIM and single wheel in the vertical plane that runs direct drive off another CIM. Top wheel is mounted slightly to left of center. Velocity is running over 30 fps and is flying flat and stable. Probably going to have to make some hefty guards for the fast spinning wheels in case of failure.
Doug
http://youtu.be/i4LRvcwTFEA
WOW! That is a great shooter! Very interesting design. I never thought of mounting the well above the frisbee before!
My team is shooting consistently at 60ft away. We are planning on shooting full court, but we don't have to if we are blocked.
VIDEO:http://www.youtube.com/watch?v=BzIke...er_profilepage
  #51   Spotlight this post!
Unread 03-02-2013, 01:39
capnslow capnslow is offline
FRC #3131
capnslow is an unknown quantity at this point
We're shooting full court, I don't know what our max range is though. Our shooter is a very different design and is powered by two (2) PG71 motors.
  #52   Spotlight this post!
Unread 04-02-2013, 21:14
vic burg's Avatar
vic burg vic burg is offline
Alumni, Mentor, & AmeriCorps VISTA
AKA: Captain Obvious
vic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to beholdvic burg is a splendid one to behold
Wow, I'm impressed! With our (4622's) first shooter we get maybe 8-9 feet at peak with 50% power and around 6 feet if it's 100% or 25% power which is really random but we're working on it and other shooter designs. We know the main issue with our shooter is the track it follows (the piece that helps to guide) is not at the right curve so once we get that fixed we'll probably be shooting further. Height is only around 5 feet, though.
RoboColts--Hallandale Elementary
--Thanks goes out to Cody C for making me ^^this^^ user bar!!!!
Nuts and Bolts help the world go 'round.... They also keep us all together. Including the Robots we build. -vic burg
I have been dubbed an honorary member of 1902 and 744 (by the members).
And yes, I am in the habit of collecting team t-shirts.
  #53   Spotlight this post!
Unread 04-02-2013, 21:30
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
We are shooting from anywhere on the field. We can shoot full court with about 80% accuracy with a speed of about 54 feet per second at around a 10 degree angle. Variable angle shooter allows for up close shooting. Mecanum drive. Current projected weight is 100 lbs. I'd post a video if I had one. I will asap!
We make easy things look difficult, everyday!
  #54   Spotlight this post!
Unread 05-02-2013, 22:37
JohnFogarty's Avatar
AKA: @doctorfogarty
Yeah, we have a shooter capable of longer than full court shots. We'll be able to change our shooter's angle for different distances as well. at 80% accuracy without speed control. Imagine what it will be with speed control. (;
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
  #55   Spotlight this post!
Unread 05-02-2013, 22:56
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
We made a full court 3-pointer on Sunday (yes, yes, video) and went a miraculous 4 for 8 from the feeder station today. Unfortunately no video of that yet, but if we can't replicate it for the camera tomorrow it won't much matter that it happened today.
Generally though, we still intend to shoot from the back of the pyramid through the rungs (we ended the night hitting 12 in a row, and will occasionally miss 1 in 20). We can also hit from a few other places touching the pyramid. It's an arc shooter (<90deg) with a direct drive mini-CIM and a white HiGrip or a custom bike tread on a plaction wheel (we've had success with both--still deciding). 1/2+" compression, in and around a 20deg angle, depending on exactly how we feed into the wheel.
