Go to Post Inspiration is a two-way street. - Taylor [more]
Unread 28-01-2013, 17:17
barre006 barre006 is offline
FRC #2526
barre006 is an unknown quantity at this point
Centering Camera and Robot
We need to figure out how to get our camera to center itself on rectangular objects.
Basically, we can get the camera to take a picture and recognize the rectangle as a target. But the rectangle in the image isn't centered. We want the robot and camera to move until the rectangle is in the dead center of the camera and the image, that way we can aim correctly.
Thank you in advance for any assistance you might be able to offer us, we're really looking forward to finally using vision targeting this year.
Unread 28-01-2013, 17:48
2472Programer 2472Programer is offline
Programming Captain
AKA: Dane Jensen
FRC #2472 (The Centurions)
2472Programer is an unknown quantity at this point
Re: Centering Camera and Robot
I faced this problem a few weeks ago and here is my solution
 private void centerShooter() {
        ColorImage image = null;
        BinaryImage thresholdImage = null;
        BinaryImage bigObjectsImage = null;
        BinaryImage convexHullImage = null;
        BinaryImage filteredImage = null;
        int biggestindex = 99;
        int widest = 0;
        int highest = 0;
        ParticleAnalysisReport[] reports = null;
        try{
            image = camera.getImage();
            thresholdImage = image.thresholdRGB(0, 25, 20, 225, 0, 225);
           // thresholdImage.
            bigObjectsImage = thresholdImage.removeSmallObjects(false, 2);
            convexHullImage =  bigObjectsImage.convexHull(false);
            filteredImage = convexHullImage.particleFilter(cc);
            reports = filteredImage.getOrderedParticleAnalysisReports();
            for (int i = 0; i < reports.length + 1; i++ ){
                if ((reports[i].imageHeight > highest) && (reports[i].imageWidth > widest))
                    widest = reports[i].imageWidth;
                    highest = reports[i].imageHeight;
                    biggestindex = i;
                    System.out.println("Problem's not here");
                System.out.println("Test");
                SmartDashboard.putString("Filtered Image", filteredImage.toString());
                outputstring = "Height = " + reports[biggestindex].toString() + "Width = " + reports[biggestindex].toString();
                System.out.println (outputstring);
                SmartDashboard.putString("Dimensions: ", outputstring);
                SmartDashboard.putInt ("Targets Found", reports.length);
                SmartDashboard.putInt("height of Target", reports[biggestindex].imageHeight);
                SmartDashboard.putInt("Width of Target", reports[biggestindex].imageWidth);
                if(reports[biggestindex].center_mass_y>centerdown){
                    increaseShooterAngle();
                    Timer.delay(.3);
                    shooterAngle.set(Relay.Value.kOff);
                    System.out.println("Increase");
                }else if(reports[biggestindex].center_mass_y<centerup){
                    decreaseShooterAngle();
                    Timer.delay(.3);
                    System.out.println("Decrease");
                }else{
                    System.out.println("You're Good");
                if(reports[biggestindex].center_mass_x>centerleft){
                    toTheLeft();
                }else if(reports[biggestindex].center_mass_x<centerright){
                    toTheRight();
                }else{
                    tank.tankDrive(0, 0);
        }catch(Exception ex){
            //System.out.println("Failed");
            SmartDashboard.putString("Error", ex.getMessage());
        }finally{
        try{
            filteredImage.free();
            convexHullImage.free();
            bigObjectsImage.free();
            thresholdImage.free();
            image.free();
        }catch(NIVisionException ex){
This still isn't perfect, as most times the robot completely misses the vision target, a problem that I must face today, and this code likes to also track white light... no explanation needed and in terms of the Y axis tracking, you may want to have a sensor that can tell you the angle of the shooter and have the shooter move until it is at the right angle.
Unread 29-01-2013, 00:49
divixsoft's Avatar
divixsoft divixsoft is offline
FRC #0835
divixsoft is an unknown quantity at this point
why not calculate the angle, than use a gyro with a pid loop to turn?
Unread 29-01-2013, 03:43
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Hey, try checking out my guide. It explains how to do the vision processing parts of what you're trying to do.
As for the rest, check out my code for automatic turret tracking. RobotMap.top[0] is the reported x coordinate of the center of the detected target. If you're doing your own vision processing, just pass it that value as such. CameraXOffset is just 160, the x value of the center of the camera's vision. HorizontalTurretAxis.rotate() is a method I added to HorizontalTurretAxis, but replace that with whatever you want the PID output to be of course.
If you need more explanation on how this works please ask.
TL;DR image processing sends x,y coordinates of detected target back to a command that runs a PID controller using that coordinate as input and your motors as output to align itself.
