Go to Post it's not because the kids look up to him that [Dave] gets picked on, it's really because it's just so much fun. - MissInformation [more]
Unread 29-01-2013, 10:19
Ori1302 Ori1302 is offline
FRC #4320
Ori1302 is an unknown quantity at this point
Communication Problem
Hello Chief Delphi,
We have a problem with the communication between the computer and the Robot.
When we connect to the Crio or to the radio directly with the LAN cable, we dont have any problems at all..
But when we try to connect to the robot with Wireless, the communication is lost every few seconds for something like 7 seconds and then the connection returns again, the problem is not with the Crio or the rest of the robot because when we connect the computer directly the connection is good, I dont think that the problem is with the radio either because we tried to connect to two different ones and the problem was with both of them.
We dont know what is wrong and if it is a problem with the hardware or with the software, please help us to solve this problem.
Unread 29-01-2013, 10:30
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Communication Problem
I would check your cpu usage on the crio, and also how much network data you are using in each connection mode ( use task manager's networking tab for a graph)
Do you have the same issue with default code? If yes, then your problem has to do with the connections. If no,then your user code is suspect.
Good luck!
Unread 29-01-2013, 11:25
It might be interference from other devices. Do you have a 2.4 GHz cordless phone nearby? What other wireless networks are in the area? If you can do a scan and find a relatively clear channel, you can log on to the D-Link and configure it to use that channel.
Unread 29-01-2013, 14:28
FRC #4320
We solved the problem, We set the radio configuration again and the problem vanished.. thanks for the help!
