Go to Post sigh, I started wondering why we weren't there than I realized it was in California. Thats a bit of a road trip... - Raumiester2010 [more]
  #31   Spotlight this post!
Unread 29-01-2013, 03:45
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Safety Alert please read!
Originally Posted by fox46 View Post
I've been mulling this around in my head after seeing the kids had been experimenting with pneumatics this past weekend. In the interim, if teams insist on using the plastic tanks rather than switching to metal, what about placing some sort of containment device around the tanks? I was thinking a heavy sock with tie wraps around where the pneumatic tube connects to the fitting. At the very least it should help contain any shrapnel or at least reduce its kinetic energy should one rupture.
I wonder whether mere tensile strength is sufficient, or whether the shearing action of those shards in motion is a consideration? And do small shards pose less of a risk due to their small mass (like birdshot compared to buckshot)?
Although your suggestion of a sock sounds pretty good, what about versions of the mesh bags used to contain onions and other similar vegetables? (Those might be easier to incorporate into existing designs.)
Originally Posted by Seth Mallory View Post
Our tank is a different production style but why take any risks with the students.
This is an opportunity for a good discussion on risk, and what drives prudent decision-making. How much of the hazard and the associated uncertainty are realistically transferable between the specific tank that failed, others in its lot, others of the same model, others in the product line, and other product lines of similar manufacture? Or is this strictly a matter of perception being everything—action is being taken, so outsiders will perceive it as the responsible course of action?
I'm curious about what specific factors are driving your decision—not particularly to criticize you, but to discuss the proposition that a drastic response often isn't a methodologically valid way to approach a spectacular failure.
After all, you (and everyone else) obviously take plenty of risks with the students. It's our responsibility to try to manage those risks in a sensible way.
  #32   Spotlight this post!
Unread 29-01-2013, 07:48
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Originally Posted by ftc3799 View Post
.....During robot testing today we had a catastrophic failure of two of the new Clippard Air Tanks simultaneously. Luckily no one was seriously hurt. We had them pressurized to approx. 110 psi and during leak checking they blew apart into small shards ........
2 tanks burst at the same time? What was the 'leak checking' procedure? (tightening fittings or spraying soap?)
Were the tanks connected together with a common brass fitting, or a flexible hose between them?
  #33   Spotlight this post!
Unread 29-01-2013, 08:15
Guys,
The OP posted that further examination showed what appeared to be a manufacturing defect in the plastic. Please remember that these tanks have been used on FRC robots in the past without failures.
  #34   Spotlight this post!
Unread 29-01-2013, 08:21
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Dave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant future
In addition to Al's statement above: Clippard, FIRST and AndyMark take safety VERY seriously and all of those parties are currently evaluating the situation. I believe they will have a statement and course of action very soon.
"Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
FRC Team #144 Advisor
  #35   Spotlight this post!
Unread 29-01-2013, 09:21
Racer26 Racer26 is offline
Al, correct me if I'm wrong, but I was of the impression that these Clippard tanks were new, and not before tested in an FRC environment, but that they were an answer to similar model tanks from another manufacturer used in the last couple FRC seasons by some of the heavy hitters like 217 and 1114.
  #36   Spotlight this post!
Unread 29-01-2013, 10:30
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Yes the Clippard tanks are new and not what we used last year. We will be harvesting the tanks from last years bots until this is resolved.
  #37   Spotlight this post!
Unread 29-01-2013, 11:05
dudefise dudefise is offline
FRC #2637 (Panthers)
dudefise is an unknown quantity at this point
Would it make it safer to put a wrapping of duct tape around them, at least for testing and until we are given an actual course of action? I realize this would likely render them illegal, but might help to contain any shards since dict tape usually splits on a seam.
2010 VRC 2453B - Team Captain
2011 FRC 2637 - Electrical - Las Vegas Regional Semifinalists with 1726 and 166
2012 FRC 2637 - Electronics Captain - Las Vegas Regional Semifinalists with 1661 and 2984
2013 FRC 2637 - Build Captain - Inland Empire Quarterfinalists with 3925 and 207
2014 FRC 2637 - College Mentor - Central Valley Quarterfinalists with 2085 and 5136 / LA Regional Semifinalists with 696 and 5102
2015 FRC 2637 - Lazy Schmuck - Couch Sitting Quarterfinalist
2016 FRC 2637 - College Mentor - SD Regional Finalist with 1572 and 2443, Excellence in Engineering, Wildcard
  #38   Spotlight this post!
Unread 29-01-2013, 11:20
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
The chemicals in the adhesive of duct tape could also potentially weaken the plastic, I would be wary of this as a solution.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
  #39   Spotlight this post!
Unread 29-01-2013, 11:29
Theoretically, same materials, similar specs. I would suspect we are going to have a response soon. Please be patient. Use the tanks from last year in the meantime.
  #40   Spotlight this post!
Unread 29-01-2013, 12:48
pfreivald's Avatar
AKA: Patrick Freivald
Originally Posted by Tristan Lall View Post
That's just the thing: apparently some state OSHA offices prohibited PVC pipe outright (e.g. Arizona, from which the quotation at issue was sourced) without specifying whether they were only talking about the conventional PVC water pipe. Unless they are confident that no safer PVC pipe can be made, they should only restrict the specific products that pose the hazard.
Indeed they should, but all too often people who don't understand the science behind a decision are the ones who make it, especially when the government is involved...
I'll never forget teaching in California when a law was passed (unanimously by both houses and signed into law by Governor Davis) that outlawed "chemicals made from dangerous elements" in science classrooms... Further investigation indicated that "dangerous" included anything "toxic" or "flammable".
Not withstanding the absurd misunderstanding that toxicology is a matter of dosage (and that even water ingested in sufficient amounts is toxic), the ignorance of even middle school level chemistry was quite astounding.
Among the things unintentionally outlawed in California science classrooms: matches, table salt, water, air, humans.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #41   Spotlight this post!
Unread 29-01-2013, 12:52
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
My thoughts around using the sock was that they would be elastic and absorb the energy of an expanding tank while allowing the compressed air to permeate the fabric and release pressure. The onion bag idea could work as well but are they not a relatively non-elastic material?
I think since the duct tape would be wrapped around the tank tightly it would tear as the tank expanded. I feel it would also contain the compressed gas which could cause it in itself to burst like a balloon.
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
  #42   Spotlight this post!
Unread 29-01-2013, 13:17
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I'll just leave this here...
Kevlar Biaxial Sleeving
I do not advocate teams reinforcing their plastic tanks.
Though the added weight a reinforcing a plastic tank might make metal tanks weight-effective again. They will certainly be safer.
  #43   Spotlight this post!
Unread 29-01-2013, 13:53
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
From the Tristan
"I'm curious about what specific factors are driving your decision—not particularly to criticize you."
No criticism taken. Here is the reasons for my actions. Another school had an accident a few years ago and we are under a microscope. A failure of one of our tanks after being the alerted to the problem would cause us serious trouble. Our students run our machine shop and welder. I do not want to risk that program. The type of tank is not critical for out prototype and the definitive answer should be out in time for the final robot. While we all manage risks all the time because of our situation this risk is not needed or worth taking.
  #44   Spotlight this post!
Unread 30-01-2013, 17:08
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
FYI, here is an email I just received.
Dear FIRST Team Member,
Clippard has been made aware of an incident where the white
polypropylene air tank had burst. There are several factors that
could have led to this and Clippard is evaluating the issue. We have
yet to replicate the occurrence at a pressure below 700 psi, and
believe this to be an isolated occurrence. However, working with
tanks under pressure can lead to dangerous circumstances and
precautions must be taken.
Until a full evaluation is complete and in the interest of safety,
Clippard recommends that your team dispose of their current tanks and
replace them with the SS-1154, the 32in3 metal version, at no charge.
To replace your tank, reply to this email and include your team name
and number of tanks to be replaced. We apologize for any
inconvenience and wish you all success in your upcoming competition.
Sincerely,
Clippard Instrument Laboratory, Inc.
  #45   Spotlight this post!
Unread 30-01-2013, 17:15
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
You really can't beat that for customer service!
2016: Lake Superior WFFA
